Enclosed are pictures and drawings of 370805-S100, J-Clip, used on 64-70 Mustangs behind the instrument cluster. The clip is attached to the LH side to retain various wiring harnesses on all models, and is used on 64-66 convertible with electrical tops replacing two plastic 377986-S clips.
As far as I can determine, there is no Ford drawing available from any current documentation.
I took a couple of clips from my electrical collection and made a sketch, pic 1
- took pictures of my samples, pic 2, 3 and 4. Pics 3 and 4 show the vendor ID (see drawing).
- Pic 5 shows a typical installation of the clip from the 66 Mustang Electrical Assembly Manual (E6-8155-1, AM0013 pg 29). Item 9 is the clip; item 10 is the screw, 358735-S2. Other years are different.
- Pic 6 shows the replacement of the regular clips (377986-S) behind the instrument cluster, item 13, using screw, item 8, 42127-S2, for convertibles.
