Author Topic: Power Windows Power Source  (Read 5412 times)
Offline Mark69Sportsroof
« on: November 03, 2017, 11:05:23 PM »
Hi Everyone,
I am trying to test each of the power window motors and need to know which wire is the power.  I have taken the window motors out of the car and I have a red wire and a yellow wire.  I'm trying to verify which motors are any good.  I believe the window switches are non functional and will need new ones or have the current ones re built.  Thanks Mark
« Last Edit: November 03, 2017, 11:39:49 PM by 69mustang73mach1 »
Mark
1969 Ford Mustang Sportsroof, 390-4V
Dearborn built on Oct 31, 1968
1973 Ford Mustang Mach 1, 351C-4V
Dearborn built on Oct 31, 1972
Offline GT500KR
  • Charlie Ping
Re: Power Windows Power Source
« Reply #1 on: November 04, 2017, 04:09:22 AM »
   The answer is both are power, and both are ground. Just not at the same time. ;) The switch reverses the polarity, and the direction of the motor, to make the window go up and down. In other words, one is power, and the other is ground to go up, and the reverse is true for down.
Current Project:
64.5 Black DB Cpe
5F07D1131XX  4/14/64
The stable:
65 Ivy Green Coupe 4SPD
68 Candy Apple Red GT500KR 4SPD FB
70 Grabber Blue Boss 429
86 Jalapeño Red GT  5SPD
91 Emerald Green Saleen Conv. 5SPD
03 Sonic Blue Cobra Conv.
07 Black GT500 Cp
« Reply #2 on: November 04, 2017, 11:38:51 PM »
Thanks GT500KR.  So in order to bench test the motor I could just attach a wire to a battery + post and a wire to a ground and the motor should work?
Thanks Mark
Mark
« Reply #3 on: November 05, 2017, 12:30:44 AM »
Be advised. Those motors generate a lot of torque and draw a lot of current.
Offline GT500KR
  • Charlie Ping
« Reply #4 on: November 05, 2017, 06:32:07 PM »
Yes,
  But use as large, or larger gage wire as the existing wires on the motor to power it, and place the motor in a vice or other fixture before testing. I like to pull the gear and dogs out, and let the motor run for a few minutes in each direction to clean up the brushes. Then inspect, replace and pack new grease in the transmission.
Current Project:
64.5 Black DB Cpe
5F07D1131XX  4/14/64
The stable:
07 Black GT500 Cp
« Reply #5 on: November 05, 2017, 11:06:21 PM »
Thanks again.  I will try it and keep you all updated.  Thanks Mark
Mark
