Author Topic: Wiper motor ground wire  (Read 1605 times)
Offline RocketScientist
« on: October 31, 2017, 09:50:49 AM »
I am assuming that the wire attached to the wipe motor is a ground wire but where does it connect to the car? it's a March 70, car.
Re: Wiper motor ground wire
« Reply #1 on: October 31, 2017, 11:17:45 AM »
front of cowl  is a grounding hole.
« Last Edit: October 31, 2017, 11:19:54 AM by specialed »
« Reply #2 on: October 31, 2017, 05:05:42 PM »
To illustrate Eds comments
Red arrow is the mounting screw for the bracket (someone must have placed what was left of the ground wire there so not to lose it)
Green arrow is the grounding wire - goes to a separate grounding location on the face of the cowl
« Reply #3 on: October 31, 2017, 09:28:19 PM »
Thanks everyone. When parts get old and crusty it can be hard to tell what's right and wrong.
« Reply #4 on: November 01, 2017, 12:53:49 PM »
So is the grounding screw finish P&O ?  Will that be a universal finish for all years and plants ?  Brian
« Last Edit: November 01, 2017, 04:10:00 PM by Brian Conway »
« Reply #5 on: November 04, 2017, 08:52:01 PM »
For a 69 NJ car the wiper mount bolt in the visible cowl looks to be P&O while the ground wire screw appears to be the typical zinc dichromate that we often see associated with electrical applications of this type
Example picture E7 in the link below. Type of screw and washer may have changed during 69 NJ production as I found a different style used late in the year but that detail  does not relate to your car
http://www.concoursmustang.com/forum/index.php?topic=16181.msg101308#msg101308
« Reply #6 on: November 04, 2017, 10:01:48 PM »
Great.  Thank you Jeff
