Author Topic: 65 AC car correct radiator fan and spacer  (Read 1466 times)
Offline 69cobrajetrugae2
« on: October 22, 2017, 09:16:28 AM »
Question.
  I am in the process of installing what appears to be a factory 3 row radiator in a 65 Fastback factory AC car. The fan must be installed lastly since there is no radiator installation clearance with the fan installed.
What is the correct procedure and what fan and spacer are used?  It seems to me that a slotted fan mount must be used and the spacer may be bolted on separately. Thanks!
Offline ChrisV289
Re: 65 AC car correct radiator fan and spacer
« Reply #1 on: October 22, 2017, 01:58:08 PM »
Are you not using a fan clutch?
2009 V6 Mustang Coupe
« Reply #2 on: October 22, 2017, 02:19:45 PM »
Chris, it has a solid fan.  Did the factory use a fan clutch on AC cars?  thanks!
Offline ChrisV289
« Reply #3 on: October 22, 2017, 03:03:24 PM »
As far as I know they did.  How many blades is your fan?
« Reply #4 on: October 22, 2017, 05:02:46 PM »
What engine?
With the aftermarket 3 row radiator on my daily driver 66 Hardtop (289 "A" code, AT, PS, no A/C) I used a 68 spacer with four shorter bolts
and a shroud. (Not concourse.)
« Reply #5 on: October 22, 2017, 06:17:18 PM »
Guys. it's a 4 blade fan.  I have to do a trial fit and report back, thanks again!
Offline ChrisV289
« Reply #6 on: October 22, 2017, 07:53:36 PM »
I'm running a three row radiator with a five blade fan and fan clutch and shroud.
« Reply #7 on: October 22, 2017, 11:19:22 PM »
'65 factory A/C would typically be a 5 blade w/clutch.
« Reply #8 on: October 23, 2017, 04:34:06 PM »
Thanks again!
Is it true that the factory did not provide a 3 row for 65/66 mustangs AC or Not?
« Reply #9 on: October 23, 2017, 04:51:14 PM »
Thanks again!
There was what is referred to as a Desert Cooler radiator that was an option but pretty uncommon. Can be seem in other threads
