Author Topic: Fuse Box Lettering - How did they do it?  (Read 4022 times)
« on: October 14, 2017, 02:22:17 PM »
My question is how the fuse box letters are painted white with sunken letters.   There must be a quick way of dipping the fuse box face into paint such that the recessed letters retain the paint, but how do you get the paint off of the higher surface, leaving the paint in the recesses?
I'm scratching my head on this...
I don't think there were lots of folks using hypodermic needles full of white paint carefully painting the letters...
Re: Fuse Box Lettering - How did they do it?
« Reply #1 on: October 14, 2017, 03:30:57 PM »
i've used a water based paint, laying the paint into the letters then wiping the face with water....have no idea how the factory did it.
« Reply #2 on: October 14, 2017, 04:13:26 PM »
Similarly, I did mine with a light brushed on pass of white Testers model paint and cleaned off excess with a single layer toilet paper, not the thick-fluffy kind, dampened with lacquer thinner and came out perfect in my opinion.
« Reply #3 on: October 14, 2017, 04:31:58 PM »
When I worked in "Hi-Tech" in the 60's, we used a rubber "squeegee" like device to remove excessive paint from engraved lettering. That's about all I can remember.
« Reply #4 on: October 14, 2017, 05:52:47 PM »
+1. Me too.
« Reply #5 on: October 14, 2017, 05:58:18 PM »
Ran across a couple of people that were using Liquid Paper years ago, Guess it might not be a good choice if you lived in a humid climate
For those that are not old enough to remember the stuff  ::) This was correcting liquid to correct typing errors on paper when we use to use those things. Originally invented by the mother of one of the members of a famous  TV musical band of the 60's
« Reply #6 on: October 14, 2017, 06:49:57 PM »
Yup, the Monkees' Michael Nesmith.  The inventor was Bette Nesmith Graham.
« Reply #7 on: October 14, 2017, 08:04:52 PM »
Reconditioning my fuse box for me?  ;)
« Reply #8 on: October 14, 2017, 09:00:00 PM »
No...there's not enough money in your bank account for me to do that!  Dammit, Jim, I'm a Doctor, not a painter!
I'm just curious.
I thought that the manufacturers of the boxes would dip each one into a wet wax pan to just cover the surface, let dry.  Then dip it in a bit deeper pan of white paint, let dry,  Then apply a bit of heat or go back to the first pan to wet the wax and wash off.  If they did this, I would expect to see a bit of white paint into the fuse receptacles themselves, so that's not the way they did this.  I still think a huge workbench of school lunch ladies working carefully to apply white paint with needles is a more interesting image...
Silk screening?
Offline drummingrocks
« Reply #9 on: October 14, 2017, 09:20:06 PM »
But if it was silk screened, would there still be a need for recessed letters?  Seems like the silk screening would wear off because the letters would be slightly raised from the surface of the box itself.
« Reply #10 on: October 23, 2017, 09:33:26 PM »
I now have many fuse boxes to experiment with.
I had one that had some rust stains on the interior from the fuse clips.
So I used that one and my original broken tab version for this experiment.
First stop is into the sink to remove all of the old grunge using Dawn and a toothbrush.
Here is what I used to clean the rust and polish the outside:
That nets this:
On the inside of the fuse area I used a small wooden stick to polish that area and remove rust:
A toothbrush removed the left over polish.
On to paint. I found some acrylic paint in the wife's studio along with a very small brush. I also found a patch of some linen. I wanted linen as it has almost no fuzzies on it. You need cloth that will not go into recessed paint area. Paper towels are also out.
Apply enough paint to go into the recessed area. That may take some daubing. No air bubbles should be present in the lettering areas:
I only let the paint sit 30 seconds or so before I applied a slightly wetter than damp linen to the top surface. It took a few passes and I ended up with this:
It looks really sharp and takes only a few minutes.
« Reply #11 on: October 23, 2017, 10:31:09 PM »
Nice work!
Offline Mike_B_SVT
« Reply #12 on: October 25, 2017, 05:55:39 PM »
Ok, at the risk of exposing my inner-geek...
https://youtu.be/6BYZNCn6WoE?t=17
Now "back in the day" we would use a wax crayon to fill in the lettering, then wipe the surface with a paper towel.  But I guess the "kids" nowadays use a Deco marker from the craft store.
Mike B.
1 of 354 in Sonic Blue
Cat Bites Man!
« Reply #13 on: October 25, 2017, 07:49:30 PM »
Wow!  I think that's the way to do it in the future!  Nice find, Mike!!  Now...where's the nearest Hobby Lobby? DecoColor Paint Pens by Marvy.
Offline BKnapp
« Reply #14 on: October 26, 2017, 08:26:18 AM »
Mike - awesome link. Thanks for sharing! I tried something similar on my heater controls, but that looks way easier.
