I typically twist one way and then the other way all the while putting pulling pressure on it. It can very very tight so you have to put sufficient pressure to get it to move. It should un thread off by doing it this way. It does for me. Sometimes it will crack and self destruct when trying to take it off . If you are lucky it will pull straight off with out much effort.
Consider using an OEM filter also...
