Author Topic: 1966 t-code brake booster vacuum line?  (Read 748 times)
Offline dsielke
« on: October 02, 2017, 01:22:23 PM »
Is anyone making the correct metal power brake booster vacuum line for the 200 that goes from the intake over the valve cover? I can find it for the 289 but not the 6. :(
6R09A138419: 1966 GT Fastback, Springtime Yellow
6R08T138429: 1966 Convertible, Tahoe Turquoise
Re: 1966 t-code brake booster vacuum line?
« Reply #1 on: October 02, 2017, 06:30:53 PM »
Don't believe so
The style shown in the thread below is two piece. Solid steel line from the intake to almost valve cover then a flex line then a short solid line again then the flex hose to the bottom of the booster.  On this example there are two (large and small)  connections at the base of the booster (plastic check valve). But that may be  because its a Thermactor car and the vacuum source for the smog check valve
http://www.concoursmustang.com/forum/index.php?PHPSESSID=hcmgvjcmnv74skh0fo7aiod5k4&topic=13678.msg84628#msg84628
Offline dsielke
« Reply #2 on: October 02, 2017, 07:53:53 PM »
Mine is also a thermactor equiped california car. That is the tube I need just don't know where to find one. Somewhere in the past it was cut off at the vacuum block in the intake and a rubber line run all the way from there. Probably from getting damaged somehow.  It really is harder to find parts for a 6 cylinder than a v8. :(
btw, my trans and thermactor had lines running to the vacuum block in the intake, not a split at the booster. Though that could have been changed somewhere along the line. There are two smaller lines that come out the side one immediately connected to a metal line that came around the back to the smog and the other a rubber line to a metal line at the top of the bell housing and a larger screw-in towards the front that went to the booster. the screw in was cut short.
« Last Edit: October 02, 2017, 08:00:12 PM by dsielke »
Offline dsielke
« Reply #3 on: October 08, 2017, 07:25:32 PM »
I was able to find a good original line at Mustangs Etc. getting closer and closer. :)
