Author Topic: 67 Front Brake Hose Clips  (Read 656 times)
Offline bhoulis
  • 67 GT350
« on: September 25, 2017, 07:49:42 AM »
Are the AMK front brake hose clips correct for a 67. March 22, San Jose, disc brakes? The ones I took off have the raised tab running all the way across the clip, while the AMK ones have a raised tab that is shorter, only about 2/3 the width of the clip. Also what should the correct finish be? Thanks. Brian
Re: 67 Front Brake Hose Clips
« Reply #1 on: September 25, 2017, 08:13:52 AM »
All of the originals that I have seen have the tab running all the way across. IMO they were phosphate and oil finish. If your originals are not too badly pitted I would have them replated.
« Reply #2 on: September 25, 2017, 09:00:48 AM »
+1, originals I have seen have a 'P' stamped into the middle of the edge that shows when installed.
« Reply #3 on: September 25, 2017, 08:54:02 PM »
Here is a couple of pictures to help others understand what is being discussed
Disc brake application
Drum brake application
