Author Topic: Rear drum brake anchor pin PLATE  (Read 2463 times)
Offline Matt1968
« on: September 20, 2017, 08:44:32 PM »
Spent hours researching this part and still no conclusive answer.  Mustang Unlim and NPD list this as part # 2028.  Ford # c4uz-2028-a.  Description says this part is only for 9" diameter drums.  Does anyone know why they would not work on 10" ? My 10" drums are either missing these or did not come with them.
This video shows them being used during the rebuild:
But I am seeing websites and other videos where people are not even using these plates during their brake rebuilds.   Are they even necessary?  What is the real story?
Offline PraireBronze
Re: Rear drum brake anchor pin PLATE
« Reply #1 on: September 20, 2017, 09:59:10 PM »
"brake shoe guide anchor pin" is a only used on 6 cylinder mustangs.  I don't know why.  The 8 cylinder backing plate does not have the necessary boss on the pin.
- Tim -
1965 Prairie Bronze 2+2 (under construction)
Build Oct '64 San Jose
289 4V Automatic Transmission (A-code clone :P )
Black Std Interior
AC, PS, Style Steels, 1" Drop, Konis
Aluminized 2 1/4 Exhaust, Tri-Ys
Offline Matt1968
« Reply #2 on: September 20, 2017, 10:17:40 PM »
This picture was sent to me by Jack at dead nuts on of his 69 cj with the same elongated diamond shaped plate as seen on the video mentioned above
« Reply #3 on: September 21, 2017, 04:29:05 AM »
Matt what year and model are you working on??  Might be the place to start  ::)
Offline Matt1968
« Reply #4 on: September 21, 2017, 08:59:27 AM »
Anyone?  Someone must be knowledgeable on this plate.
« Reply #5 on: September 21, 2017, 04:10:36 PM »
Yes but not sure if it applies to what your working on since you haven't provided that information.  See reply #3
« Reply #6 on: September 21, 2017, 04:39:59 PM »
That's what I'm waiting for also.  Cuts the research time way down
Offline 196667Bob
« Reply #7 on: September 21, 2017, 06:23:59 PM »
I guess it could be a 1968 based on his username ? On the other hand, he might be 49 ??
Bob
MCA 04909
Offline Andrew@MagMustangs
    • MagMustangs
« Reply #8 on: September 21, 2017, 06:30:17 PM »
Simple answer for you Matt1968. Yes, you need them for your 68 390 car. All 68 Mustangs had them and you need them specifically for 10" brakes. 6 Cylinder cars with 9" brakes or Full-Size cars with 11" brakes used a different plate.
