Author Topic: 1970 Mustang 428 CJ carburetor spacer and gasket  (Read 1046 times)
Offline Myfo28
« on: September 16, 2017, 01:12:07 PM »
About to install rebuilt D0ZF-AB carburetor on my 1970 Mustang 428 CJ with reproduction spacer and gasket.  Should the gasket be installed as shown or should it be trimmed to match the spacer?  Thanks
1970 Mustang 428 CJ Convertible
Ravens Black
R Code
Re: 1970 Mustang 428 CJ carburetor spacer and gasket
« Reply #1 on: September 16, 2017, 03:48:23 PM »
Would install as shown without trimming the tabs for your year and application
Offline 7Lscjracer
« Reply #2 on: September 16, 2017, 05:55:57 PM »
+1
All the carb to spacer gaskets I've seen are 4 hole, but spacer to aluminum intake is open plenum while spacer to cast iron intake is again 4 hole.
Bought May '81, sold Sept '20
Offline Myfo28
« Reply #3 on: September 16, 2017, 06:48:29 PM »
Thank you both!
Ravens Black
R Code
« Reply #4 on: September 16, 2017, 07:44:49 PM »
Just make sure the the diameter of the holes in the carb base plate, intake and spacer (well when they have 4  holes) all have the same diameter.
There are gaskets with all kinds of configurations but not normally factory ones ;)
