Author Topic: 5 or 6 bolt bellhousing  (Read 1177 times)
Offline michaelvonlanthen
« on: September 14, 2017, 03:28:49 PM »
I am wondering if I have the correct engine for my 289 V8 D-Code engine. I am unsure, since someone who inspected the car told me, it would be a 6 bolt. I have searched a bit in the internet and compared pictures, I guess it is a 5 bolt. Can someone please verify?
thanks a lot, Michael
Michael Vonlanthen
Switzerland
5F08D189*** - 76A   F   42   06G    75   1   6
Guardsman Blue Convertible with white interior, AT, PB, AC, console, Rally-Pac
Re: 5 or 6 bolt bellhousing
« Reply #1 on: September 14, 2017, 04:42:24 PM »
D codes should be 5 bolt.  (all generator V8's)
« Reply #2 on: September 14, 2017, 04:46:59 PM »
For your own peace of mind, check the casting part number behind the starter (it should be C4OE-6015-?) and the assembly date on a pad near the distributor, see the attached.
« Reply #3 on: September 14, 2017, 05:15:19 PM »
Thanks Charles and Jim,
I guessed, we can determine it by the form/design of the bellousing. I will check the casting part number next time in the garage.
Michael Vonlanthen
Switzerland
« Reply #4 on: September 14, 2017, 06:23:08 PM »
Another method for a quick check is to measure the distance (just has to be rough) between the two upper block to bell housing attaching bolts
« Reply #5 on: September 14, 2017, 07:05:16 PM »
Casting number for 5 bolt bellhousing is C3AA-6394-C; for 6 bolt: C5DA-6394-A
« Reply #6 on: September 15, 2017, 11:32:18 AM »
So auto trans ?
« Last Edit: September 15, 2017, 11:37:31 AM by Brian Conway »
« Reply #7 on: September 15, 2017, 02:17:56 PM »
So auto trans ?
The car owned by the OP is an automatic.
