Author Topic: Suspension Markings 69 GT with Handling Package  (Read 1640 times)
Offline windsor
« on: August 30, 2017, 04:02:04 AM »
Hi, I'm from Switzerland and I’m new here.
This site helped me a lot already restoring my car concours correct :)
Car is a 69 (Built Oct.68 @Metuchen) Export GT convertible 351W 4bbl, FMX, P/S, P/B, 3.25 rear end, no A/C.
Can anybody tell me what the correct leaf and coil springs markings are? Apparently the GT’s had the handling package with heavy duty suspension.
What color were the leaf springs anyway?
Any help would be much appreciated.
Thanks Oli
Re: Suspension Markings 69 GT with Handling Package
« Reply #1 on: August 30, 2017, 02:21:47 PM »
Guess you didn't find a build sheet in the car since that would show you the colors. To make a better guess or to be certain what are the engineering numbers from your leaf springs?
Get back to us with that info while I search my notes to see if I can offer some solid answers
Search feature is your friend - Similar question was asked in this one  bur realized that I need to rebuild the links so will do that in the next day or so
http://www.concoursmustang.com/forum/index.php?topic=12633.msg76714#msg76714
Offline windsor
« Reply #2 on: September 01, 2017, 04:40:29 AM »
No build sheet unfortunately :-[
Ok thanks!
I'll clean the old springs and try to find some numbers. They are pretty rusty.
Offline windsor
« Reply #3 on: September 02, 2017, 11:55:23 AM »
Ok i found the number C9ZA5556C
I even found the stripes under a thick layer of tar!:) One is yellow but i can't tell what the other one was. looks brownish but hard to tell.
any ideas?
« Reply #4 on: September 02, 2017, 05:32:52 PM »
Thanks for the picture and numbers
My best guess would be one gold (what you see as yellow) and one brown stripe
This would match the same rear springs as the H and M code Mach I's that used the heavy duty suspension - and likely the same as the GT package.
After all the years what we see today and without cutting through what remains today colors don't always reflect what they may have looked like originally though in other examples they do. Add to that the differences in digit cameras, that they do to pictures and monitor settings and they can be all over the place. The picture below is just and example
Top stripes were originally two yellow stripes. The center was  pink and orange while the bottom was gold and violet
« Last Edit: September 02, 2017, 05:42:37 PM by J_Speegle »
Offline windsor
« Reply #5 on: September 06, 2017, 01:39:43 PM »
perfect, thank you very much :)
