Author Topic: Correct Oil Pressure Sensor 1967 289 with Tach?  (Read 4257 times)
Offline Ralf
« on: August 29, 2017, 01:50:37 PM »
Hi,
Looking for the correct (NOS) oilpressure sensor for my 67 with tachmeter (+ speedometer incl. tripometer)
(with oilpressure warning lamp)
Great to post a source/pictures + part number
289, small bock, C4 automatic
Saw a lot of different (repro) types, but all with description only for tach (pic# 1 and 2)
Picture #3 shows mine (cable not connected), not sure if this is really the correct unit. However, the warning lamp is not working, even with cable connection. Assume unit has a defect (cable works, see pic #4).
Many thx
Ralf
« Last Edit: August 29, 2017, 04:27:21 PM by J_Speegle »
Re: Correct Oilpressure Sensor 1967 with Tach?
« Reply #1 on: August 29, 2017, 04:12:36 PM »
According to the January 67 version of the MPC (attached) you are looking for the B6A-9278-B, and not the much more common C6SZ-9278-A used on the cars with gauges instead of lights.
The 65-72 MPS also lists B6AZ-9278-B, with a supplementary number of SW-667.
The third picture is a purported NOS Motorcraft (not Autolite mind you) SW-667.
Hopefully someone with an original will chime in with information that will confirm, clarify or perhaps correct the information I gleaned from the MPCs
Re: Correct Oil Pressure Sensor 1967 289 with Tach?
« Reply #2 on: August 29, 2017, 04:45:44 PM »
O.P.'s picture of the new one (so is John's NOS Motorcraft) is (are both) correct if based off what is found on my 11/66 built example.
The larger "Bell-Shaped" is for an oil guage dash, not "OIL Light" version that is used on the tach dash version.
Hope this helps.
I know of another member with a November 4th build date small block at this site, maybe he will chime in also with his knowledge.
« Reply #3 on: August 29, 2017, 06:53:09 PM »
NOTE - Moving the thread since it focuses on one particular year
Kind of a pain to find pictures since PS and AC was becoming more popular in 67
The small sender was used for the light (with tach) option
Confirming that the gauge used the bell style - here are some examples. As a side note this was the typical shape from what I can recall of the sending units seen in the 50's and early 60's Fords
Yes there are a few "creative" details in the pictures    ::)
Looking at the read reference it shows the following for replacements
SW-667 for the oil sender without tach and trip
SW-673 for oil sender with tach and trip
390 uses different sender
Did use the Cougar heading since the Mustang section of the book is a mess (unusable  ::)
« Last Edit: August 29, 2017, 07:17:02 PM by J_Speegle »
Offline Ralf
« Reply #4 on: August 30, 2017, 02:31:00 AM »
Thanks to all for supporting.
If I understood correctly.
Btw. My car has AC....any difference?
1. B6AZ-9278-A
SW-667, for oil sender with tach and trip
Warning Light 67 - 70: With Factory Tach, 289, 302, before 6.5.68
2. C7ZZ-9278-A
SW-673, for the oil sender without tach and trip
67- 68  With Gauge (without Factory Tach, With Spade Connector)
However, there is a difference to what Jeff is saying:
vs.
What John has posted
The 65-72 MPS also lists B6AZ-9278-B, with a supplementary number of SW-667, with tach and trip odometer.
I'm confused ....;-)
« Last Edit: August 30, 2017, 02:57:20 AM by Ralf »
« Reply #5 on: August 30, 2017, 02:33:08 AM »
No difference with AC
« Reply #6 on: August 30, 2017, 04:20:24 AM »
The large bell shaped style is for a gauge to show a range of pressure on the gauge . The small button sender is for a warning light also referred to for decades as a "Idiot light" (just what it is called). The small button one is not very complicated inside. When the oil pressure drops very low (I am not sure but I think under 5lbs of pressure) it makes a contact like a doorbell and lights the warning light bulb.
Offline Ralf
« Last Edit: August 30, 2017, 08:58:01 AM by Ralf »
« Reply #8 on: August 30, 2017, 09:22:10 AM »
@ John
Would you consider to sell your Motorcraft Sending Unit?
And this is what confuses me as well:
https://www.calmuscleparts.com/OIL-PRESSURE-SENDING-UNIT-1967-69-289-302-wo-tach-tripodometer-1965-66-6-8-cyl-wgauges-1967-68-200-390-wo-tach-and-tripodometer-1968-70-289-302-390-428-wo-tach-tripodometer-1968-427-1969-71-Boss-302-wo--P20921C2294.aspx
Do not take everything you read in catalogs as truth. The best of them make mistakes, may be the wrong photo.
Offline Ralf
« Reply #9 on: August 30, 2017, 10:07:48 AM »
Yes true. The reason why I'm here. Lots of specialists around :-)
Nevertheless, you can go crazy if you do a search only by your own, not knowing exactly the details.....
Online krelboyne
« Reply #10 on: August 30, 2017, 12:16:40 PM »
The Ford Master Parts Catalog created all of the convoluted descriptions for the oil pressure sending units, and the alternator wiring harnesses too.
Bob got it right, big bell with analog gauge, smaller one for warning light.
« Reply #11 on: August 30, 2017, 12:45:30 PM »
Technically, it's the other way around. As oil pressure rises above the minimum (your 5psi is very probable) the switch is deactivated and the "idiot" light goes out. You are right about the rest.
« Reply #12 on: August 30, 2017, 01:47:10 PM »
tomatoe/tomato
Thanks for the tech incite Jim, we NOW all know why it's called an "idiot light"  ;D ;D ;D ;D lol!
« Last Edit: August 30, 2017, 01:49:21 PM by 67gtasanjose »
« Reply #13 on: August 30, 2017, 04:33:58 PM »
@ John
Ralf, that is not mine, I found it on eBay.  It was active at the time of my post, not sure now.
A Motorcraft version of this part is not particularly difficult to find.
« Reply #14 on: August 30, 2017, 04:40:19 PM »
@ John
My question is why in the world does the "tripodometer" has anything to do with what oil pressure sending unit is needed?
