Author Topic: 1965 coupe rear quarter extension  (Read 2957 times)
Offline rodster
« on: August 11, 2010, 11:13:50 PM »
Not something you normally see (inside of extension) but I found a C5 NOS piece (left) is made different than the one originally on the car.
Was there any type of sealer installed between the extension and the quarter?
« Last Edit: August 11, 2010, 11:18:51 PM by rodster »
1965 Dearborn Mustang Coupe
Raven Black - Palomino Pony
1967 Dearborn Mustang Conv.
Wimbeldon White - Red
1984 SVO - 2A
Re: 1965 coupe rear quarter extension
« Reply #1 on: August 11, 2010, 11:38:44 PM »
This is generally accepted as a 65 vs. 66 change, with the part on the left being the '66 version.  Don't know the exact change in production, can probably check some resources in a few days that might yield an idea.  If you decide to use the one on the left, it does require a rubber gasket, which is available in reproduction... same as the 67/8 style material.
Offline rodster
« Reply #2 on: August 12, 2010, 12:01:35 AM »
Interesting....thanks Charles. The one on the right is off of my 65 April 19th Dearborn car. I suspect it's original. Funny they didn't use a gasket on the early cars, just a gap between the extension and the body.
Seems like the 66 version could fit without using a gasket?
1984 SVO - 2A
Offline NEFaurora
« Reply #3 on: August 14, 2010, 10:44:35 PM »
Yeah, Ford was weird with this stuff. The 1968-1969 Falcon had a similar deal.
The 1968 Falcon extentions were actually made of fiberglass and had no rubber seals, and the 1969-70 Falcon extentions were made of metal and had the seals. Both year seals were interchangeable. I'm sure that the Fairlane was the same. I think Ford played around with various methods on the tailight extentions through the 60's..at least that's what I've found.  I have also found that Canadian Plants had different parts than U.S. Plants, though the Mustang does not play into that of course.
Tony K.
MCA#70001
Offline rodster
« Reply #4 on: August 14, 2010, 10:50:46 PM »
The more I learn, the less I understand!  ;D
Thanks....
1984 SVO - 2A
« Reply #5 on: August 14, 2010, 11:02:46 PM »
The '66 version will fit, but you need to use a gasket.
Offline rodster
« Reply #6 on: August 14, 2010, 11:48:12 PM »
Is the gasket visible? If so, a 66 version wouldn't be concours correct for an early 65 right?
(Slowly trying to learn about these early cars!!!)    ;)
1984 SVO - 2A
Offline buckeyeresto
« Reply #7 on: August 15, 2010, 12:03:50 AM »
These will fit a 65,66 however their are many revisions to the quarter extensions and the pins are different on each revision to match the quarter panel.  so their for a 1964 quarter panel c5zz-a for example the holes will line up with the pins on a c5zz-a quarter extension however a c5zz-a quaterpanel will not line up with a c5zz-b quarter extension make sense?  thats why you see many quarter panel reemed out to make the quarter extension fit.  You don't have to used the gasket if you don't want to on your 65 but some quarter adustment will be necessary
« Last Edit: August 15, 2010, 12:05:52 AM by buckeyeresto »
Offline rodster
« Reply #8 on: August 15, 2010, 12:48:19 AM »
Interesting.. I'm amazed at the number of changes on these early cars.
1984 SVO - 2A
Offline mustangmann
« Reply #9 on: August 25, 2010, 02:50:36 AM »
Sorry to hi-jack this topic, but there were both fiberglass and pot metal rear quarter extensions used in 1969.  I have had both, but cannot recall the engineering numbers on them.
Ken
