Author Topic: Battery Ground Cable Routing - 69  (Read 6492 times)
Re: Battery Ground Cable Routing - 69
« Reply #15 on: August 29, 2017, 05:18:49 PM »
The photo with the 70 dodb  plastic hold down bracket could be a early70 cj car ?
Here is a wider look at the same picture from the magazine.  Looks to be 69 style shock towers but what do you think?
« Reply #16 on: August 29, 2017, 05:59:10 PM »
Looking at where the horns are located it would seem to be SCJ car ?  Missing the oil cooler, using wing nuts on the air cleaner, corner of the forward-upper right C9 valve cover is missing ? The service decal on my Metuchen car is vertical.  This one appears horizontal.  Maybe a clue there  ?  The only hint that it might be a 70 are the shock tower braces.  I can barely make out the extra bracing at the firewall side ?  Gotta squint real hard.  Brian
« Reply #17 on: August 29, 2017, 06:21:11 PM »
Lack of hood pins is my first wonderment as well as the moved and no cooler(just like 69 Boss 302s) There does seem to be a depression in the rubber radiator seal around the passenger side hole
Inspection stickers suggest Dearborn as well as the stapled on radiator seal.  The 69s also used had the reinforced shock tower braces
Not sure what your seeing when you refer to the valve cover is missing.
69 style shock tower braces, later cast 69 - 70 valve cover style
Being a magazine car could explain the wing nuts on the top section of the shaker. So "fine tuning" of these cars was the nor to get better reviews by the writers ;)
« Reply #18 on: August 29, 2017, 07:09:09 PM »
The valve broken cover is a smog pump hose super imposed ?   Any clues with the battery heat shield or no ' caution ' on the radiator shroud?  Brian
« Reply #19 on: August 29, 2017, 07:30:11 PM »
Looks like the bottom cover may have been bumped - just needs to be pushed up and reseated
Don't see anything that would indicate that.  Touching up pictures at the time would not be the norm for a car magazine
Heat shield has the bump up lip, it appears) on the long end suggesting that its a C7 (correct for up to 69) rather than the 70. The CAUTION FAN sticker would have been installed if the car had been serviced after 1971 at a dealership or the owner applied one after receiving a letter n the mail from Ford in 1972 or replaced the shroud with a service replacement boxed after 1971 (still had to take the sticker and stick it on the shroud in the early versions) .
Not a factory decal placed on new cars other than Boss 429s with the open (very small in comparison) finger guard
« Last Edit: August 29, 2017, 07:32:39 PM by J_Speegle »
« Reply #20 on: August 29, 2017, 07:42:35 PM »
No ' Cobra Jet ' on the shaker scoop ?  Just an observation.  That hose coming off the air cleaner base, right side, and going down behind the snorkel and heat riser is what ?   Brian
« Last Edit: August 29, 2017, 07:49:01 PM by Brian Conway »
« Reply #21 on: August 29, 2017, 07:52:24 PM »
............. That hose coming off the air cleaner base, right side, and going down behind the snorkel and heat riser is what ?   Brian
That would be a hose for the vapor recovery system (California thing in 70
Picture is a confusion or mix. Possibly an engineering or test car for multiple 70 features that was released to the media
Wish I had a copy of the complete article to at least have a time frame and some context to measure things by - even though you can't believe what was in print  ::)
« Reply #22 on: August 29, 2017, 08:46:05 PM »
That would be a hose for the vapor recovery system (California thing in 70)
Ding!, that is what I was thinking. California 1970 paper tube, going to charcoal canister. Would also say it is an automatic car, based on vacuum advance.
Offline Steve.chatman
« Reply #23 on: December 23, 2017, 03:52:39 PM »
Would a 69 GT350 battery ground rout the same way?
« Reply #24 on: December 23, 2017, 05:14:50 PM »
If you mean outside of the hold down bracket then yes.  You can see much else that would apply in the pictures. A better illustrated routing for the 351W is in the electrical manual of the assemblyline manual set.
