Author Topic: Steel distributor vacuum line  (Read 683 times)
Offline Hipo giddyup
« on: August 23, 2017, 12:42:01 PM »
 I'm curious if anyone knows if the steel vacuum distributor line has a flared end to hold it into the distributor fitting and carb? This would be for a 1966 Metuchen built car .
Re: Steel distributor vacuum line
« Reply #1 on: August 23, 2017, 01:33:53 PM »
A brass compression nut, 351112-S, is used at each end.
« Reply #2 on: August 23, 2017, 01:58:40 PM »
Thanks , I do have those but even after tightening , if you pull hard enough it will move. That's why I was asking.
« Reply #3 on: August 23, 2017, 04:39:10 PM »
- I do have those but even after tightening , if you pull hard enough it will move.
Yeah. If you look inside the holes, on both the carburetor and distributor, where the compression nut threads into, you should see an inward ring-like protrusion that deforms the nut and "should" keep the nut from pulling off the tube, which may deform as well. I have a couple of used vacuum lines that the nut is bonded to the tube and won't move. Remember, stainless tubes are harder and less likely to deform.
« Reply #4 on: August 23, 2017, 06:34:52 PM »
+1 on the stainless , that's why I never buy those.  ;D I'll just have to be careful not to hit it. Wondering how much vacuum I could be losing with a " loose fit"?
