Author Topic: Location of "D" clips for Wiring under the solenoid - 68 Metuchen  (Read 1980 times)
Offline dave6768
I've discovered that there are no holes in the replacement inner fender underneath the starter relay.  Need to know what size and where to put the two holes for the D clips and the wire routing .  Anyone (Jeff) of have a picture of this area?
I think I may have found a few posts that "had" pictures, but thank you Photobucket.
68 GT J code, Metuchen, convertible.
Dave
Offline dave6768
Re: Location of "D" clips for Wiring under the solenoid - 68 Metuchen
« Reply #2 on: August 21, 2017, 10:26:52 PM »
Thanks Jeff!
Offline rodster
« Reply #3 on: August 21, 2017, 11:26:11 PM »
Here's a picture with everything removed.  I think you can see the hole locations.
1965 Dearborn Mustang Coupe
Raven Black - Palomino Pony
1967 Dearborn Mustang Conv.
Wimbeldon White - Red
1984 SVO - 2A
Offline dave6768
« Reply #4 on: August 22, 2017, 01:47:52 PM »
Thanks...even better.    It looks like there's only on D clip under the solenoid?
« Reply #5 on: August 22, 2017, 05:05:34 PM »
The original question was for the location of the hole for the clip, 382184-S.  Pictures are nice, but they don't tell a lot, like measurements. This could be answered by someone with a tape measure and a 68 Mustang doing some leg work. A different clip was used on a 67, 352541-S, but probably used the same size hole and location.
« Reply #6 on: August 22, 2017, 05:39:26 PM »
Jeez, talk about shaming!
Here's one I'm putting together now.  Early April '68 NJ build
« Reply #7 on: August 22, 2017, 06:42:18 PM »
The original question was for the location of the hole for the clip, 382184-S.  Pictures are nice, but they don't tell a lot, like measurements.....
The holes would have been stamped at the plant so IMHO  if the hole on my car was off by a 1/4" I wouldn't suggest moving it.  Not like he's making a inner fender panel ;)
Think suggesting exact measurements and using the term "probably" are very consistent :)  Think the PS would be better served with the same plant and year just in case  ::)  JMHO
Offline dave6768
« Reply #8 on: August 22, 2017, 09:50:39 PM »
Thanks Charles.  I thought there were two clips as I see in your photo.  Curious, what's the white strap on the right.   Another curiosity, I do not have the block (not sure what it's called) for the convertible top that I see in your picture to the left of the solenoid.  Is it possible that I never had one, or did it possibly get moved by a PO?
« Reply #9 on: August 22, 2017, 10:20:12 PM »
I'm not sure what white strap you're referring to??
The junction block on the lower right is for the power top.  Since this is a '68 Shelby, the block up top by the solenoid is for the ammeter wiring.
Offline dave6768
« Reply #10 on: August 23, 2017, 10:42:35 PM »
I guess the white strap is the junction block for the power top.
Do judges carry tape measures....LOL :P  I think if I get them close, I'll be good to go.
« Reply #11 on: August 24, 2017, 12:50:34 AM »
Ah, yeah.  I believe that has to be fixed too, where the center is punched through the stud.
I doubt any judge would know the exact location.  If you can wait until after the weekend, I can put a tape measure on it.
« Reply #12 on: August 24, 2017, 01:42:07 PM »
Finally.
Offline dave6768
« Reply #13 on: August 24, 2017, 09:56:04 PM »
Thanks Charles....I can wait.
« Reply #14 on: August 28, 2017, 10:47:35 PM »
Here you go...
