Author Topic: 67 SPEC case  (Read 2161 times)
Offline preaction
67 SPEC case
« on: August 20, 2017, 07:14:11 PM »
Is it possible for a 67 500 to have received a 67 427 car (maybe a Comet) center section and not a SPEC case ?
Re: 67 SPEC case
« Reply #1 on: August 20, 2017, 09:55:59 PM »
I suppose it is possible but it would be out of the ordinary and not likely. FYI the majority of GT350's did not have spec cases.
Re: 67 SPEC case
« Reply #2 on: August 20, 2017, 10:37:41 PM »
I'm clueless  :-\ ; what is a SPEC case?  Google does me no good. :-[
Re: 67 SPEC case
« Reply #3 on: August 20, 2017, 11:01:50 PM »
Identification for high strength big bearing 9 inch center section . Marked SPEC in place of the date code. I have always been under the impression that SPEC=Special. FYI some center sections upon inspection are the same even though not marked SPEC. Spec case is typical on 67 427 Fairlane and 67GT500.
Re: 67 SPEC case
« Reply #4 on: August 20, 2017, 11:41:33 PM »
The letter SPEC is interesting since its been found on a limited number of other cast parts.  But for this discussion thought a picture would help.  Have seen a number of original 67 Shelby's that received dated cases instead of the SPEC case - not sure why. Likely some issue at the rearend plant
There are single vertical and dual vertical 9" SPEC cases out there so be careful. The double or dual vertical ribbed design has an extra horizontal rib and the dates for each are located in different locations. For this application  you want a dual horizontal ribbed case
There are also early (without the fill plug) and later (with the fill plug) versions
Offline preaction
Re: 67 SPEC case
« Reply #5 on: August 21, 2017, 03:56:45 PM »
Jeff, do you mean early and late for the fill plug on  the center section or housing ?
Re: 67 SPEC case
« Reply #6 on: August 21, 2017, 04:38:58 PM »
Yes both. They started out only on the housing then they changed the design to include them as part of the 3rd member casting. Them later dropped them from the housing design though the change to the no plug in the housing is not a real IMHO cut off since we find groupings of housings with plugs into late 67 San Jose use
Because of this some will refer to the earlier 3rd member as beign the one without the filler plug and the earlier housing to be the housing with the filler plug
