Author Topic: detail questions  (Read 1685 times)
Offline mach1one
detail questions
« on: August 09, 2010, 12:32:02 AM »
Trying to put the finishing touches to 3/5/69 dearborn 428 convertible 4sp car 3.50.1) any color code on the Z bar. 2)horn bolts and nuts. Build manual says soft cad bolts and P&O nuts? 3)Is there a strap that holds both heater hoses together? again build manual shows one under full vacuum options?4)Does the center console on a convertible have 6 or 8 screws to hold down the center console? my car which had some pan replacement only has 6, the 2 missing are over the convertible brace. Thanks for the help Lu
Re: detail questions
« Reply #1 on: August 20, 2010, 11:10:27 AM »
White stripe on Z bar for CJ front to back across the width of the flat bar -about a inch from where the bar bends up to accept the pedal rod. The Z bar is bare steel color and not silver zinc (1970 thing). no straps on hose. There should be a screw in each hold down hole in the console plastic. Bob
