Author Topic: Zinc Plating -  (Read 5378 times)
Re: Zinc Plating -
« Reply #15 on: June 12, 2019, 01:12:39 AM »
Thanks for the feedback guys.
I thought that might be the case and the moss killer is a killer idea!
Offline RocketScientist
Re: Zinc Plating -
« Reply #16 on: June 12, 2019, 09:10:46 PM »
I use a zinc anode from a marine supplier for my anode.
Does anyone know what the brightener is?
Brad
Re: Zinc Plating -
« Reply #17 on: June 12, 2019, 09:53:14 PM »
I have one of those boat anodes, but the zinc flows from anode to part and I was worried I would get shading unless I sat there turning the part.
With multiple zinc strips (3?) do you get a better zinc coat?
Youtube video of a guy plating everything for his 911:
Re: Zinc Plating -
« Reply #18 on: June 12, 2019, 10:41:23 PM »
Brad
If you want the plating to be shiny plan on adding brightener every so often. If you don't mind it being dull don't add any.
Offline Countrysquire
    • Houston Vapor Blasting
Re: Zinc Plating -
« Reply #19 on: June 13, 2019, 11:53:05 AM »
Brad
I get the brightener from Caswell, but don't know what the chemical actually is.  I think they keep it a secret so they can charge you $15 for the little bottle.
Bobby Crumpley
MCA#20316
www.houstonvaporblasting.com/
64.5 Dearborn Coupe
5F07D173***
65A M 86 20F 62 1 5
Re: Zinc Plating -
« Reply #20 on: June 13, 2019, 12:00:45 PM »
Plenty of info on the web, this one might be interesting:
https://patents.google.com/patent/US3112251A/en
Re: Zinc Plating -
« Reply #21 on: June 13, 2019, 12:45:25 PM »
So it's some sort of saccharide, interesting.  I guess one could do hours of experimenting and get the formula that works...or just spend the 15 bucks with Caswell every few years.
Bobby Crumpley
MCA#20316
64.5 Dearborn Coupe
5F07D173***
65A M 86 20F 62 1 5
Re: Zinc Plating -
« Reply #22 on: June 13, 2019, 01:26:46 PM »
I'm ok with spending the money for the Cadwell CopyCad solution, their brightener and the dichromates.
But $24 for that small plate of zinc -- uh, no.
