Author Topic: 1966 289 engine oil dipstick tube with thermactor  (Read 3200 times)
Offline socalgt
« on: July 23, 2017, 11:51:58 AM »
Does the engine oil dipstick tube mount any differently to the engine with the thermactor system?
Offline lancelot66
Re: 1966 289 engine oil dipstick tube with thermactor
« Reply #1 on: July 23, 2017, 12:33:25 PM »
Nope, same hole bolted up to the block all by itself. Since the coil is located on top of the intake, the same hole is not used for both the coil bracket and dipstick. Just the dipstick. Sorry I don't have a specific photo to post.
VR/
-Lance
SJ Build Date: 1/6
Many Original Options
« Reply #2 on: July 23, 2017, 04:56:46 PM »
A question remains on a 66 smog engine, was the retaining bolt painted or not? It would have been initially clear zinc (378604-S8) as installed, but when?
A similar question about 65 289 dip stick tubes, the coil and its bracket were installed after paint. Was the painted bolt removed and reinstalled with the coil? Would Ford change assembly line practices for 66 smog vs. 66 non-smog dip sticks?
Offline lancelot66
« Reply #3 on: July 23, 2017, 06:55:13 PM »
Those are some good questions Jim. I left mine unpainted but I have no firm reasoning behind doing this. My "guess" and what probably makes the most sense is that with smog, it got painted with the rest of the motor, timing chain cover, water pump, etc. Without, because of the coil and bracket, not painted because it was added later after engine paint. Does anyone know I'm now wondering?
VR/
-Lance
SJ Build Date: 1/6
« Reply #4 on: July 23, 2017, 07:26:07 PM »
I cant say to how the smog equipped were done but a comment was made about non smog cars.  I have many observations on non smog survivor type hipo engines. All three plants had SB from Cleveland engine plant so they would logically be consistent on base engine items like being discussed. I have observed (no reason to think non hipo would be any different) The dipstick tube was painted . The dip stick was typically painted but seen some that were not(maybe had been replaced?). Coil bracket was more typically painted then not on 65-early 67.  67 on up was just reversed in that the coil bracket was more typically unpainted then painted.  Many vintage engine shots (GT350's  were often photographed and written about in magazines of the day) seem to confirm what I have observed. Just what I have seen others may think differently.
« Reply #5 on: July 23, 2017, 08:57:13 PM »
Dip stick tube, dipstick and attaching bolt were painted engine color like the Thermactor mount
For the dipstick tube, orientation and location of the finished product
Not an eay thing to get pictures with so much going on in the area
Coil and bracket were not painted (on things we deal with here) engine color for any of the classic period. I'm about 50/50 on painted verses unpainted (black) coli brackets for 65-67 small block applications - slightly less than half I would report
Offline lancelot66
« Reply #6 on: July 24, 2017, 09:38:47 AM »
Thank you Jeff. Great to confirm this. I had remembered an older post where you had stated the smog pump bracket got engine color so I have that correct. So now, time  to find my long handled paint brush and touch up that dipstick bolt.
VR/
-Lance
SJ Build Date: 1/6
