Author Topic: Ford Four Speed Shifter  (Read 4494 times)
Offline racincast
  • may 65 FB Metuchen
Re: Ford Four Speed Shifter
« Reply #15 on: January 12, 2025, 07:00:05 AM »
Hi Bob,
that's exactly main issue, bolts are larger than shifter lever holes (only thread go in) so I'm not able to install the rubber and put bolt inside the lever, as shown on the photo bolt do not go further. Does exists different holes diameters on levers and I do not have the correct bolt and rubber for mine?
Thanks for your help
Jos
Fastback GT 5T09A16XXXX
WIMBLEDON WHITE
Bright Red Interior
« Reply #16 on: January 12, 2025, 01:26:53 PM »
Hi Bob,
Jos
You still never answered if the shifter lever is a new one  (never before installed) or old (original that was on before)?  It is ether a issue of the hardware being wrong or the shifter handle being made wrong. There were not two size holes that I am aware of originally.  The rubber bushings should fit snug but allow the bolts to go through. If your hardware threads into the shifter control and looks like the picture then you know that the hardware part is right. Of course If you haven't left anything out and going only by the things that you say then drilling out the holes on the shifter lever will solve the problem.  You may or may not want to pursue other alternatives like sending back to mfg if a new one recently purchased.
Offline racincast
« Reply #17 on: January 12, 2025, 02:54:33 PM »
Hello Bob,
shifter level it's an old one.
Not in the car when I bought it, unfortunately is not easy to drill lever holes as it's heat hardened as regular drill bits doesn't drill it.
If there wasn't to sizes I can't figure out what is causing this.
sorry for the trouble and thanks
Jos
WIMBLEDON WHITE
Bright Red Interior
« Reply #18 on: January 12, 2025, 03:36:57 PM »
Hello Bob,
Jos
Maybe since the shifter lever wasn't in the car when you got it that it didn't go to the car but from another application.
« Reply #19 on: January 12, 2025, 03:45:20 PM »
Let's do a simple "test". The correct shoulder bolt, 379818-S8 has a screw threat of 5/16-18 with an effective thread length of 15/32, almost 1/2 inch (or 13MM). Remove ONE fender bolt and use that as a gauge to check the threaded hole in the shifter and the screw thread on the shoulder bolts. The fender bolts have a thread of 5/16-18 (the same as the shoulder bolt) and can be "tried" to match both the external threads of the bolt and internal threads of the shifter. For reference, 379818-S8 is available from AMK products https://www.amkproducts.com/ AMK stock number B-12630.
Offline racincast
« Reply #20 on: January 12, 2025, 04:14:21 PM »
Hello Jim.
the tread is that one but shifter hole has 5/16 too but bolt diameter where rubber should be placed is wider
Jos
WIMBLEDON WHITE
Bright Red Interior
« Reply #21 on: January 12, 2025, 05:00:41 PM »
I suppose you can check to see how much a machine shop will charge to drill the 2 holes to the proper size or buy a different handle that has the typical diameter holes.
« Reply #22 on: January 12, 2025, 07:38:11 PM »
Sort of good news bad news. Your not crazy for one but I found out what the problem is. It is a early shifter lever used the small hole shift handle (not positive on the application)and the later style 65-67 Mustang used the large hole style with the rubber bushings and odd bolts. I found the shift lever among my parts and posted a comparison picture to show the difference. It has been so long ago I don't remember what car it came off of . It is not the bent style like is typical 64 1/2 Mustang style. You are left with the same options as talked about before. I seem to remember a set up like this that used a regular bolt and a rubber coated steel washer under the head.
« Reply #23 on: January 12, 2025, 07:48:04 PM »
I would mention that drilling out the hole should not be a option IMO. The small hole has a thinner base then the large hole lever. The larger hole is not straight through . The hole goes a little less then have way and then has a lip before continuing the rest of the way. The center of the rubber bushing sits in that lip. I don't think it is worth the trouble to replicate that design. I think your best option is to buy ether the early bent shifter lever if you think it is appropriate for your build or the later curved 65-67 lever. Of course you could stick some regular bolts in it with the mention steel coated rubber washer or equivalent and see how that works out.  Given the trouble of fitting the boot and the taking up of carpet to change a shifter lever I would want a sure thing the first time.
Offline racincast
« Reply #24 on: January 13, 2025, 05:55:08 AM »
Thanks Bob,
happy find I'm not getting crazy...just older. I remember now another detail, when I rebuild my 4 speed transmission I noticed that the lever knob was not the correct one but didn't think that the lever simply was not from this assembly.
Yeah I'll try to find one already rebuild with new rubbers on the "T" as most of you recommend on several other posts.
Thanks to Jim too for his "deep technical" help
Jos
WIMBLEDON WHITE
Bright Red Interior
« Reply #25 on: January 13, 2025, 08:19:20 PM »
For reference, this is what Ford Engineering "designed" (although not what the assembly line always did).
From the "1964-65 Mustang Chassis Assembly Manual" (AM0005 page 28) -
