I shall give you another viewpoint...
How much is is your car worth? Do you think that this an area you want to use a less expensive part?
Based on the time it takes to replace a harness and its importance, I would argue you want the best possible part. The two harnesses (tach vs nontach) are fundamentally different. If you change the underdash, the headlight, the engine gauge feed and the alternator harnesses also need to be changed.
I would also disagree with the characterization that Alloy harness wont stand up to the original in appearance and function. The harnesses have been used by many Shelby show cars for decades. Ford literally made hundreds of thousands of Mustangs in 1970, not every harness was the same. Alloy harnesses are new, not brittle, same connectors, same gauge wires and almost always the same colors as OEM wires.
If you need more help, I can probably do better on the price than $800, but you still need to take the others into consideration. Just something to consider. In summary, dont try to do this on the cheap.
Coralsnake68@hotmail.com
