Author Topic: Gear Oil Weight suggestion needed for 4spd gear box using original trans seal  (Read 1056 times)
Offline Sean C. Gearty
  • 1969 San Jose GT
Anyone own or restore thoroughbred level cars that are not driven, but show cars only?
    -a car that is only driven on and off a trailer for short distances
If so, there is an original seal in the back of my trans that is weeping 80Wx90 oil on me.
My question is, has anyone used a higher weight gear oil to help prevent any small leaks without damaging the trans?
   -my Mustang is a 1969 with an RUG-AE2 Trans
Thank you for your help and suggestions
Seann
« Last Edit: July 16, 2017, 07:55:11 PM by Sean C. Gearty »
Offline rockhouse66
Sean
I am certainly no thoroughbred expert, but I would suggest running only 1 qt of oil or so in the trans.  This will still be enough for the gears to pick up and sling around but should be below the output shaft seal.
I would not recommend this for a 50 mile journey, but a 1/2 mile trip would be fine IMO.
'66 GT FB
  • 1969 San Jose GT
Hey Jim,
good idea for now. Thanks!
I will reduce to one quart, and await any other direction from the forum.
