My car is about to be sprayed and I want to verify how the lower panel that runs along the bottom of the back glass and the trunk deck are welded. I welded the quarters on and the transition panel didn't need replaced; however, I had to remove the welds to get the quarters off. I have been working on the car over the last couple of years and if I recall there were four copper globs about the size of a dime for lack of a better term. Then there should be sealer in the gap. Is that correct? I tried to duplicate the copper with weld and not real sure how smooth it should be? Dearborn Jan 1969 car. If someone could post a good close up that would be appreciated. Every pic I find is hard to tell. Thanks in advance for any help.
