Author Topic: 1967 Mustang w/Big Block what finish are the block plates for the engine mounts  (Read 829 times)
Offline motor head 428
What finish are the block plates that bolt to the engine, that the motor mounts attach to.And the finish for the attaching bolts. For a Big Block Engine in a 1967 Mustang. Thank You
« Last Edit: June 23, 2017, 08:59:27 PM by motor head 428 »
Bare steel on the brackets that bolt to the block. I would use P/O on the bolt ,light P/O on the washer and zinc silver on the nut. You need to protect the bare steel brackets against rust. I use T9 Boe Shield.
Thank You, Bob
