Author Topic: 65/66 - Standard Interior Automatic Trans, Disc Brake Pad & Gas Pedal?  (Read 3470 times)
Online 67gta289
January 65
Brake pedal pad:
M/T disc C5ZZ-2454-A
A/T disc C5ZZ-2454-B
A/T drum PB C5ZZ-2457-A
A/T drum MB C5ZZ-2457-B
M/T drum MB C5ZZ-2457-C
M/T drum PB - no listing
This matches what Scott shared from the 68 MPC for the "early" dates
Clutch pedal pad:
S/T, D & F/4/S C5ZZ-7A624-A
The 68 MPC lists revision B based on Scott's reply.
Gas pedal
Use with C5ZZ-9735-A pedal assy - 6&8 all - C5ZZ-9735-B
Whereas the 68 MPC lists C5ZZ-9735-D as standard.
Offline Richard P.
January 65
Brake pedal pad:
Clutch pedal pad:
Gas pedal
+ 1 to the above. I have the same information.
BTW I took a look at the information about the 1965 strut rod washers and my book lists  1-C4DA 3A141-A and 1-C4DA 3A142A Washer, Bushing 1-C4DA 3A140-B and 1-C4DA 3A225B Nut 1-34426-S8.
I've been out of the loop for a while. I hope this helps.
