Author Topic: 67 Mustang Steering box color  (Read 2832 times)
Offline Rossco
« on: June 22, 2017, 09:18:56 AM »
Does anyone know the color of the steering box for a 289 San Jose 67? either black or metal color I assume
Ross
Re: 67 Mustang Steering box color
« Reply #1 on: June 22, 2017, 11:07:33 AM »
Ross
The case was cast steel and sometimes the top portion (what could be reached from above ) was painted with a brush once installed with black paint so flash rust wouldn't be seen from above when looking down.That was one of the engineering directions that was supposed to be done but didn't get done every time .
Offline Rossco
« Reply #2 on: June 22, 2017, 12:09:52 PM »
Bob
Thanks for that i'll repeat the process
Ross
« Reply #3 on: June 22, 2017, 03:20:46 PM »
You didn't share which box your using but both share most of the following details
For a little more detail for restoring the box since the black (if you choose to add that detail) will not cover everything ;) .
You have a cast iron main body with fresh machined surfaces at the logical and proper places.
Zinc plated - end cap/plug,
Darkened steel - adjustment cover retaining bolts
Fresh bare steel -  adjustment cover, adjustment nut,  ID tag and vent cover  and large collar nut. NOTE: Vent may have been zinc can't tell at the moment
Shaft for the pittman arm is fresh machined steel.
Digit cameras and lighting can affect how the following pictures look (contrast between finishes)  on screen ;)
« Last Edit: September 08, 2021, 04:37:41 PM by J_Speegle »
Offline Rossco
« Reply #4 on: June 23, 2017, 10:25:56 AM »
Jeff
Thank you for the photos, I have a go at the painted/brushed black top, do I include the yellow daub mark?
Ross
« Reply #5 on: June 23, 2017, 03:07:29 PM »
Jeff
Don't know - What steering box do you have (so I can figure out the application ;)  and solid shaft or rag joint ?
Offline Rossco
« Reply #6 on: June 23, 2017, 06:02:28 PM »
She has a rag joint Jeff
Ross
« Reply #7 on: June 23, 2017, 06:12:13 PM »
Going to need the tag info so that we know (paint marks can vary) if its a PS, non PS or handling package ratio/box
« Reply #8 on: September 07, 2021, 08:12:14 PM »
Zinc plated - end cap/plug,  top adjustment cover,
Jeff -- the adjustment cover is mentioned twice. The cover appears to be tumbled metal...no zinc.
« Last Edit: September 07, 2021, 09:50:46 PM by Bossbill »
« Reply #9 on: September 08, 2021, 04:38:12 PM »
Thanks - Fix and added an additional vent finish note.
« Reply #10 on: September 10, 2021, 05:40:42 PM »
I dunked my cap into muriatic acid and got no bubbles. No cad or zinc that I could find.
At least on my SMB box that has proper casting date and build date on original tag for my car.
I'm not certain but I think the adjustment screw may be hardened. Jeff's pic appears to show a dark finish.
