Author Topic: '66(San Jose) 289 A code throttle linkage setup  (Read 4647 times)
Re: '66(San Jose) 289 A code throttle linkage setup
« Reply #15 on: June 22, 2017, 06:45:21 PM »
OK, wait a second here, I just went through this accelerator linkage setup on my automatic trans 66 HiPo, and everyone was telling me my linkage was setup wrong previously. So there's a different linkage setup for and automatic verses a 4 speed? I originally had it setup similar to the the top picture on my C6ZF-F 4100 carb,..................
Jason I don't think we've agreed to an answer but at this point we're investigating and discussing  the possibility it seems. Its takes a while for us to collect documentation/examples and changes to "common knowledge" take time to digest and consider.
The benefit of a site like this is the exchange and honest discussion of new findings and possibilities. Not all pass the test and don't expect all to be received quickly.
Not sure of the history of how your car got that arrangement so I think we need to see if we can find some more original/unrestored examples to compare. Not an easy task since most engine pictures are taken with the air cleaner in place.
Offline Morsel
« Reply #16 on: June 22, 2017, 06:59:46 PM »
Haha, totally understand, I just saw this and it was such a coincidence since I was literally changing it a couple days ago based on some feedback I received on my car, so it was just a question like, "so it is a possibility the way I had it"?
But obviously I agree that I've seen so many examples of the way I have it now (bracket and spring to the linkage arm as shown in the second picture) that I was sure it must be setup incorrectly the way I had it, so I changed it. Obviously the way I have it now is a safer bet and more common. But I just found it curious that it was possible the way it was setup when I received the car. And like you said, who knows what was done to it and if a mechanic at some point adjusted and moved the spring like the first picture.
Anyway, I was just confirming and making sure I understood what was being said in the thread, and it sounds like it's more a case of "the jury is still out".
Thanks as always Jeff,
Jason
« Reply #17 on: June 22, 2017, 07:36:37 PM »
Jason,
Here's the throttle linkage on my San Jose Oct 65 GT K Fastback. The only differences between any AT and MT are the dashpot and the kickdown arm from the accelerator pedal arm to the transmission. Everything else is the same as any 4100.
« Reply #18 on: June 22, 2017, 07:57:38 PM »
Anyone else notice the bottom edge of the throttle shaft end plate (for lack of a better term)?
So far the automatic examples have a round hole at the bottom and the manuals don't. Maybe its the angle of the pictures but we have a number of pictures posted so far from multiple angles
IF so why did the maker make the difference and provide a hole/loop for an attachment?
Just discussion possibilities and observations ;)
« Last Edit: June 22, 2017, 08:10:04 PM by J_Speegle »
Offline Morsel
« Reply #19 on: June 22, 2017, 08:05:56 PM »
Jason,
Yes, this is exactly how mines setup now, looks exactly the same...
Thanks for the images...
Jason
Offline Morsel
« Reply #20 on: June 22, 2017, 08:12:36 PM »
I just pulled these carb images from mustangtek.com... These are both 4100 HiPo carbs, the shinny one is an automatic (C6ZF-F) and the older looking one is a manual (C6ZF-C), and both have the hole at the bottom throttle shaft. Now I don't know if it's different on other carbs, I did notice that one picture in an earlier part of the thread showed what you are talking about.
Also, the way I had it originally with the spring going to that hole on the throttle end plate worked great, so there was no performance issues with that setup, actually made more sense than the spring to the linkage arm IMO ;)
Jason
« Reply #21 on: June 22, 2017, 08:15:23 PM »
Lets remind ourselves that the focus is a 66 A code  just for clarification and in case this discussion is taking a new path ;)
Offline Morsel
« Reply #22 on: June 22, 2017, 08:25:04 PM »
Yes, agreed, sorry for the thread direction change :)
Jason
Offline rocket289k
« Reply #23 on: June 22, 2017, 10:22:13 PM »
The shop manual offers some clues (it validates the clip discussed earlier) and seems to imply a very simple 1 spring attachment like Jim's post (Post #18). I've scanned the page I referenced.
Ron
« Last Edit: June 22, 2017, 10:24:54 PM by rocket289k »
« Reply #24 on: June 23, 2017, 12:43:00 AM »
Problem is IMHO and in experiences the shop manual is full of generic pictures for many of the repairs.
 For all - please do not take this discussion as the final word and alter your car. We are discussing possibilities and findings nothing more IMHO at this juncture. We do this all the time off line, in person, through emails  and in phone calls.
Offline Hipo giddyup
« Reply #25 on: June 26, 2017, 03:26:59 PM »
Keep in mind that the throttles shafts can be interchanged when rebuilding. So long as they are from the same type 4100, the 1.08 or 1.12 . I can easily see where someone would swap out the throttle shaft for one that has better plating/condition.
« Reply #26 on: June 26, 2017, 03:45:37 PM »
That's why I posted to new carbs not rebuilt or factory re-manufactured ;)
« Reply #27 on: June 27, 2017, 05:10:07 PM »
Sorry, missed that... :o
Offline lancelot66
« Reply #28 on: July 03, 2017, 12:30:44 PM »
Had an opportunity to actually go out and look last night because I wasn't sure and was curious, especially about that lower hole being discussed.
We also have the same setup as Jim's #18 posting. We have that lower hole (the item I couldn't remember for certain). I think I've rebuilt this original carb at least 4 times over the years and I know I've never changed the configuration regards to bracket, spring and where it attaches.
VR/
-Lance
SJ Build Date: 1/6
Many Original Options
