Author Topic: '66 San Jose built gas tank sender wire clip  (Read 1177 times)
Offline socalgt
« on: June 10, 2017, 07:29:55 PM »
There were two clips holding the fuel tank sender wire as it is routed to the tank . Were these the same clips attached to the passenger side shock tower brace to hold wiring?  They were partially rubber coated....which wires ran through the clips on the brace?
« Last Edit: June 11, 2017, 01:18:17 PM by socalgt »
Offline socalgt
Re: '66 San Jose built gas tank sender wire clip
« Reply #1 on: June 11, 2017, 02:21:44 PM »
Found a picture of my old '66 San Jose car...I think it answers my questions...same clips and the wires in them. (The car was very original so I'm assuming this was a factory installation)
« Last Edit: June 11, 2017, 02:49:51 PM by socalgt »
« Reply #2 on: June 11, 2017, 04:39:58 PM »
Those clips are typical for the fuel sender wire. FYI NPD sells them if needed.
Online jwc66k
« Reply #3 on: June 11, 2017, 04:52:13 PM »
There are two types specified, 372046-S100 which is 1 3/16 long, and 372047-S100 which is 15/16 long. The short one is sold by AMK. The book say you need the long one. I've seen one of those types (I think Ford mix them up a lot) with its "tongue" bent upward to hold 5/16 or 3/8 metal fuel lines, and possibly the HP choke cable.
« Reply #4 on: June 11, 2017, 07:34:02 PM »
There are also 2 other variances, some with olive-drab color and dipped in black flex material and a black clip dipped in flex material.
« Reply #5 on: June 11, 2017, 11:31:05 PM »
As usual if we knew (posted) when your car was built we could provide a much better/correct answer to your question
