Author Topic: 69 Side Scoops  (Read 1457 times)
Offline 13Outlaw
69 Side Scoops
« on: May 31, 2017, 10:40:39 PM »
I notice on the side scoop in the upper back corner there is a dip in the scoop. I seem to find the same dip on most of the pictures I have found for reference. Is this normal from the factory or from over time of maybe over tightening? Thanks for any input.
1969 Mach 1 R-Code 4-Speed (Dearborn built Jan 69)
1992 GT 5.0 5-Speed
2003 Cobra
2013 Shelby GT500
Re: 69 Side Scoops
« Reply #1 on: June 01, 2017, 11:07:43 AM »
Just checked it out and yes very slight depression at the upper ext. corner.  Very slight and difficult to see actually can only be seen when sighting down the side of the car.  Brian
Offline Andrew@MagMustangs
    • MagMustangs
Re: 69 Side Scoops
« Reply #2 on: June 02, 2017, 11:44:58 AM »
It is very common and I would say probably half of them had the depression. I don't believe it was from over tightening since there is no mounting stud directly behind that area. Having had many of them still in original paint, I would say it is just a little factory defect.
Offline 13Outlaw
Re: 69 Side Scoops
« Reply #3 on: June 02, 2017, 08:29:36 PM »
Perfect, thanks!
1992 GT 5.0 5-Speed
2003 Cobra
2013 Shelby GT500
Offline Machspeed
Re: 69 Side Scoops
« Reply #4 on: June 03, 2017, 09:53:52 AM »
Interesting, as I was just going to post on this. I've owned my car since the mid seventies and have never noted this until last week. Was fixing to post on it. My car is going through a restoration and I'm considering have these depressions filled in.
9F02H205917
Offline 7Lscjracer
Re: 69 Side Scoops
« Reply #5 on: June 03, 2017, 02:46:57 PM »
I was wondering if it was a first iteration vs second of the part, but I see you are 9F02H205917 and I'm 9R02M123247.
My car predates the pot metal quarter panel extension caps, it has fiberglass ones.
I'll check my scoops when I'm home.
Bought May '81, sold Sept '20
