Author Topic: 65 Taillight Wire Loom Label - Survey  (Read 3601 times)
Offline ChrisV289
Re: 65 Taillight Wire Loom Label - Survey
« Reply #15 on: June 03, 2017, 08:10:31 PM »
My friend's Dearborn fastback. Without backup lights, November 13, 1964 build date. 5F09A352XXX
2009 V6 Mustang Coupe
« Reply #16 on: June 03, 2017, 08:13:26 PM »
Here is a picture of the label on my 65 GT 350. Pat White III here in Dallas, TX restored my original harness 25+ years ago
and I don't know if he reused the original label or not. Car is an early May 65 San Jose car being a Shelby has no back up lights, 5R09K217XXX
Texas Swede
Looks like it got installed over the assemblers ID label
Thanks for sharing
Offline Texas Swede
« Reply #17 on: June 04, 2017, 02:42:24 PM »
Thanks Jeff,
What color shall a correct one be for my early May 65 Shelby.
Texas Swede
« Reply #18 on: June 04, 2017, 06:49:45 PM »
Thanks Jeff,
Texas Swede
Would suggest red is a pretty safe guess based on when the car was built and the options
« Reply #19 on: June 04, 2017, 06:50:15 PM »
Results of the survey up to today
This is the second version. In this one I separated the coupe and fastback models and another pattern starts to appear but its easy to see more examples would help
« Last Edit: June 04, 2017, 07:05:15 PM by J_Speegle »
Offline livetoride60
« Reply #20 on: June 16, 2017, 06:31:40 PM »
....add another to the Red column for a San Jose Fastback. Without backup lights, Oct 1964 build date, 5R09K14xxxx.
...and yep, that's the original wiring & label with a pigtail repair.  The original covering is pretty much gone in this area.
« Last Edit: June 16, 2017, 06:38:53 PM by livetoride60 »
Offline ChrisV289
« Reply #21 on: June 16, 2017, 09:14:29 PM »
Not a lot of fastbacks with back up lights running around
« Reply #22 on: June 18, 2017, 11:58:45 PM »
Well the survey is tilted that way since I have collected Shelby pictures also so that give a tilt to the limited results since they didn't come with the option
Offline 65Ford
« Reply #23 on: June 24, 2017, 06:35:27 PM »
My '65 fastback follows convention:
SJ plant, with back up lights, VIN 5R09A1428xx, orange label (what's left of it).
63A  R  28  02K  51  1  5
5R09A142
Offline ChrisV289
« Reply #24 on: February 22, 2018, 12:08:54 AM »
Here is one off of a 64.5 convertible with no back up lights I worked with on Monday.  Dearborn build, 16G build date. 5F08U200XXX
« Reply #25 on: February 22, 2018, 03:34:10 PM »
5F09A728xxx
- Projected build date................. May 18, '65
- Body type............................... 09 2+2
- Plant........................................Dearborn
- Label color................................Orange or washed out red
- With back up lights or without...With B/U
« Last Edit: February 22, 2018, 03:41:04 PM by Bossbill »
« Reply #26 on: February 22, 2018, 07:49:12 PM »
Thnaks guys - will up date the spread sheet at some point
