Author Topic: rear spring saddle bushings  (Read 2395 times)
Offline Stangly
  • Gold Level Subscriber
« on: May 25, 2017, 08:16:42 PM »
Noticed in the chassis assembly manual (69) two U-shaped pads that go between the axle and the spring and the spring and the shock mounting bracket. I found them online and they are called "spring saddle bushings" by White Line for years 65-73. The AM shows for all cougar and body style 65E ex 428. Are these typically found on cars and if so has it been typically the cougars and coupes. Thanks in advance and everybody have a great memorial day weekend.
David,
68 Coupe J-Code
2001 V6 Laser Red
2015 GT Deep Impact Blue
Re: rear spring saddle bushings
« Reply #1 on: May 26, 2017, 01:15:10 AM »
The pads between the rearend housing, rear spring and the spring saddle/shock mount is not a Mustang or Shelby used item for production cars
Offline Anghelrestorations
    • Anghel Restorations
« Reply #2 on: May 26, 2017, 02:36:58 AM »
The Cougars have something like this...but not sure we are talking about the same thing here.
Marcus Anghel
www.anghelrestorations.com
Offline Stangly
« Reply #3 on: May 26, 2017, 01:20:06 PM »
Thanks for the clarification guys.
68 Coupe J-Code
2001 V6 Laser Red
Offline 1969 Cale II
« Reply #4 on: June 27, 2017, 12:11:36 AM »
Midsize cars use them. Must be a ride thing. You know, my Cyclone is better has a better ride than your Mustang. Ha Ha
« Reply #5 on: June 27, 2017, 01:42:11 AM »
No matter what you try to do to yours, it's still a Cyclone. Sad.
