Author Topic: Engine compartment - Please confirm black or cast colors  (Read 1398 times)
Offline jgkurz
« on: May 25, 2017, 12:49:48 PM »
Hello, I am in process of a restoring the engine compartment of my 1969 Mach 1 Q Code 428CJ/C6 car. In my research I have not been able to 100% confirm the colors of some of the below bolts/parts. I am going for accurate to the casual observer but not concours perfect.
My assumption is that all the bolts/parts should be "cast" in color and not black. My car was built in Dearborn in Feb 69 if that matters.
Thank you for the help.
•   Four firewall mounting bolts for export brace
•   Three studs and nuts on shock tower side of export brace
•   Front shock tops
•   Hood hinges and springs
•   Hood latch and  bolts
•   Four bolts above hood latch
•   Top of fender bolts
•   Ground screws near wiper harness grommet
« Last Edit: May 25, 2017, 12:58:53 PM by jgkurz »
Offline rockhouse66
Re: Engine compartment - Please confirm black or cast colors
« Reply #1 on: May 25, 2017, 02:04:02 PM »
I am more familiar with San Jose cars but I don't think these details varied between plants so I'll give it a shot.
zinc dichromate (gold)....and I am assuming you mean the two braces to the cowl, which I don't think would be considered "export" braces?
phosphate and oil, so a grayish flat black
•   Front shock tops
on a Dearborn (this one is plant specific) car, phosphate and oil
phosphate and oil on the hinges with the springs likely a different (darker?) color since I think they were just tempered/oiled.
P&O on the latch and I am going to say zinc on the bolts (silver)
Two inner ones are P&O and the two outer ones are zinc, though this one is controversial and someone will disagree with me here.
zinc
Hmm, on shaky ground here without checking, but if you mean a fairly large sheet metal screw I believe it is P&O
Edit:  large screw zinc dichromate small screw zinc
Some of these that I noted as zinc might actually be cad plated but for your purposes all you need to know is they are silver.
You should invest in the assembly manuals.  They are a great guide to the finishes on most of the components and fasteners.
« Last Edit: May 25, 2017, 02:43:47 PM by rockhouse66 »
'66 GT FB
Offline BKnapp
« Reply #2 on: May 25, 2017, 02:18:21 PM »
Here's another great resource. I have not looked at the 69-70 version, but the 67-68 has been a huge help.
http://www.concoursmustang.com/forum/index.php?topic=10790.0
Offline jgkurz
« Reply #3 on: May 25, 2017, 02:18:59 PM »
Thank you gentleman. Just the information I needed. Appreciate the detailed response.
« Last Edit: May 25, 2017, 08:56:17 PM by jgkurz »
Offline rockhouse66
« Reply #4 on: May 25, 2017, 02:45:23 PM »
I edited my reply regarding the wiper harness ground screws.
'66 GT FB
