The tool is intended to PREVENT the piston of the distribution block from moving during the bleeding procedure. It should only be or have been removed AFTER the brakes are found to be functioning 100% normal. IMHO, there could be no way the piston could have moved to one side or another if this tool was used the way it was intended. Using your image, the 'V" recess in the center of the piston is where the tip is the electric plug sets, preventing the switch from closing to ground. If the piston remained centered during the bleeding process, you should be able to remove the switch and see the "V" notch centered in the hole. (Fluid will not leak out of a properly rebuilt distribution valve). If the piston IS CENTERED, the switch may be at fault. If the valve is NOT centered, the bleeding procedure mentioned earlier will help you (but it still is a PITA to get this centered again this way, especially if working alone or with unskilled help)
