Get yourself a couple of fittings that fit the back side of the block, cap one off. (use your imagination or buy a cap fitting). Install the capped fitting into one of the holes (on the back side of the piston), 'thread' (using a tap) the inside of the other fitting (where normally the tubing is at...again, thread this 2nd fitting into the block on the back side of the stuck piston. Thread a grease zerk into this 'threaded fitting', pump up the pressure with a grease gun, if this won't move it, perhaps a little heat but WATCH OUT! When that HOT GREASE expands...IT WILL BURST OUT ABRUPTLY! (have a field of rags handy in the vicinity to catch the piston softly) Works every time I've tried it but use eye protection, long sleeves, gloves...you know...be smart.
