Author Topic: 67 inner fender hole functions  (Read 3959 times)
« on: May 07, 2017, 09:05:02 PM »
Looking for some assistance in determining the function of several holes in the driver's side inner fender near the firewall, below the hood hinge.
Attached is a list of 7 holes in the area.  Here is what I think they are used for.  Please correct any errors, and if you can answer the questions.
And the old adage holds true - you can never take enough pictures of a car when it is being stripped down :(
1.   (confident) this is for a white plastic clip that is taped into and made part of the main wire harness.
2.   ??? this is pretty much covered by the w/s washer supply hose and main wire harness
3.   ??? this is just below the main wire harness.
4.   (confident) this is for a black plastic retainer that wraps around the w/s washer supply hose and main wire harness.
5.   (no doubt) this is for the bolt that holds the brake distribution block
6.   (no doubt) this is for the locating pin that is part of the brake distribution block bracket.
7.   (no doubt) this is for a clip as shown in the picture to retain the speedometer cable.
Thanks in advance, John
Re: 67 inner fender hole functions
« Reply #1 on: May 08, 2017, 05:23:09 PM »
Going through pictures (well San Jose to start with)  I found that #2 and #3 were not there on all cars
On some #3 was used for the white tubular wire loom retainer
With that said will go reflect and see what I've got for Dec 66
« Reply #2 on: May 09, 2017, 11:21:20 PM »
Here is what I found in my pictures. Because this can be a tight spot and not an easy one to get photos of I also looked at it from the wheel well side
Arrows are color coded for comparison.
Wire loom retainer, retainer loop, and unused holes. Looked at the 140,000 (or close to it) through 160,000
7R01C1396xx NOTE: Almost looks like the holes (or at least one) was punched out. Notice the possible "hanging chad" at 8 o'clock on the center top hole
7R01C1399xx NOTE: No noticeable center holes like all the other panels
7R01C1627xx Hard to tell of the wire loom is using the rearmost or lower center hole as an attachment point.
7R02C1639xx NOTE: wire retainer barb changed. Possibly a different sub contractor
« Last Edit: May 09, 2017, 11:24:33 PM by J_Speegle »
« Reply #3 on: May 10, 2017, 06:07:15 AM »
The two close together holes (yellow arrows) ,on a disc brake car the upper hole is where the self tapping bolt that holds the distribution block is threaded into and the lower is for the locating tab of the distribution block.
Bob, I respectfully disagree with this statement. In regard to the O.P.'s interests and question, I believe otherwise about the two holes in question (two holes closer to the hood hinge mounting in this image)
The distribution block the O.P. Showed in his first post, though for a drum brake car, is in the same location as my Disc Brake example as well. My 11/2/66 built Disc Brake example also has the "extra holes", as shown in the image I copied and attached from Jeff's post (above). The pictures I took at dissassembly look to have been just about like this one (uncertain which hole received the harness locator at this time, but otherwise, same as pictured), with more than likely nothing inserted into these other holes in question. Close inspection of the hole with the "hanging chad" (Jeff's words), indicate nothing has ever been threaded into that hole. I do not believe these holes were ever used at this time period anyways, for the brake distribution valve. Now, we do know there was an Early/Late version of the brake lines so perhaps the later cars used these holes. Definitely room for discussion here on this topic since Jeff posted pictures of other San Jose examples without the holes.
« Last Edit: May 10, 2017, 06:09:25 AM by 67gtasanjose »
« Reply #4 on: May 10, 2017, 06:58:10 AM »
Jeff, the results of your research really does help.  The 7R02C1639xx shown above (and possibly 1627xx) is exactly where my 7R02C156xxx is at.   I restored my original harness, and it maintains its original twists and bends.  The harness clip fits naturally in the hole closest to the firewall.  I could pull and reach the two vertically mounted holes; the clip would fit in the lower but not the upper, but the harness felt more natural at the first location.   I suppose that since the hole only exposes the engine compartment to the inner fender behind the splash shield, there is no harm no foul.  I really appreciate the help!
« Reply #5 on: May 10, 2017, 12:33:50 PM »
Please excuse the post then. I removed it to eliminate confusion.
« Reply #6 on: May 10, 2017, 04:54:00 PM »
................  I suppose that since the hole only exposes the engine compartment to the inner fender behind the splash shield, there is no harm no foul.
Just as an aside those holes are visible in the front wheel well and are not behind the rear splash shield
In that picture the splash shield is in the far right edge of the picture covered with sound deadener
« Reply #7 on: May 10, 2017, 05:04:57 PM »
WOW!  :o :o :o
Most Engineers would have a problem with any water intrusion into the engine compartment!  ;D ;D ;D I imagine, since it is so well hidden, an "Engineer" might wish to put a ball of Strip Caulk into those holes, thus preventing an engine "Flooded" condition  ;D  ;)  :)
« Reply #8 on: May 10, 2017, 06:13:59 PM »
Ok ok I get it.   But I did not mention water, I had mud thrown by tires on my mind.   Notice the plugged hole about 5" directly above the two in question...   I do see the big picture now😉
« Reply #9 on: August 15, 2021, 08:32:07 PM »
Hey John, thanks for the first pic in your first post. I un-staked my valve from the bracket to zinc dichromate it and wanted a fuzzy warm feeling about the direction. It's probably the only thing on the car I didn't photograph before I took it apart.
