Author Topic: 64 1/2 Jack Handle Plate  (Read 1169 times)
Offline FXguy
    • Early 64 June K Convertible Restoration
« on: May 02, 2017, 05:58:10 PM »
Got my Jack handle back from the plater done in clear zinc.  But this and several of the other clear zinc parts came back a little more yellow than I had expected.  I'm inclined to send it back and have it redone, but thought I'd post some pics and get some input first.
TIA
-Scott
Scott McMullen
64 1/2 K Code Specialist, pre/early production historian, collector, and restorer.
"I'm absolutely sure of one thing, and that is I don't know everything...there is always something new to be discovered...and that's where the fun is."
Re: 64 1/2 Jack Handle Plate
« Reply #1 on: May 02, 2017, 08:27:56 PM »
Looks ok to me.  Some judges don't like shiny zinc  ;)
Offline FXguy
« Reply #2 on: May 02, 2017, 08:55:50 PM »
Yeah, I really like the sheen, it was just that I was expecting a clear to a bluish tone like I've seen on most of them.
Thanks for the input Charles.
-Scott
Scott McMullen
« Reply #3 on: May 02, 2017, 11:51:18 PM »
TIA
-Scott
I would not have a problem with the finish however it looks like you plated it with the spring still attached. The spring looks silver. The plating process can make the spring steel brittle and more likely to break if that is the case.
« Reply #4 on: May 03, 2017, 12:21:44 AM »
You're right about the spring getting brittle if plated, but I don't see a spring.
Scott,
Did you separate all the pieces prior to plating?
« Reply #5 on: May 03, 2017, 01:23:39 AM »
Scott,
I hope that i am mistaken .
Offline FXguy
« Reply #6 on: May 03, 2017, 02:39:34 AM »
Yes i took the spring out before plating.  It's not installed back in the picture.  Must be a shadow.
Thanks to you all!
-Scott
Scott McMullen
