Author Topic: correct pcv parts 390 4v  (Read 1727 times)
Offline martin
« on: May 01, 2017, 02:57:02 PM »
There was no pcv system on my car when i bought it. I am trying to figure out what are the right parts for the first section going from valve cover to back of carb spacer.
I have a 390 4v prior to 02-21-1969. A picture of a correct setup would be nice.
Martin
69 mach 1 390 toploader
built at San Jose Oct-25-1968
Re: correct pcv parts 390 4v
« Reply #1 on: May 02, 2017, 11:38:43 PM »
Brass fitting (with one threaded end like the CJ) connects the PCV and the hose
Hose is the typical alligator texture hose between the brass block and the engine connection. Straight on one end - preformed at engine end
« Reply #2 on: May 03, 2017, 12:09:32 AM »
Mansfield Mustang sells parts. He has a nice picture on his sight. http://mansfieldmustang.com/04-41.jpg
Offline martin
« Reply #3 on: May 07, 2017, 07:03:14 AM »
Thanks for the information.
I did also find the manfield pictures but they are for the 390 gt. I could not find pictures of a 390. Maybe it is the same as the 390.
I also had my doubt if it is correct for the prior to 02-21-1969 390 mustang. Because of this info:https://secure.cougarpartscatalog.com/store/Search.aspx?SearchTerms=C9Z%20390%20pcv%20hose
I think i will go for the model shown in the manfield picture.
« Reply #4 on: May 07, 2017, 03:28:43 PM »
Are you asking about a car other than a Mustang or Cougar?  Only S codes were installed so not sure what the issue is with the pictures (including the Mansfield ones)  is
Will check and compare the pictures and when each of those were built. As for your link I think its kind of odd that the picture shown as a reproduction carries the incorrect markings for the application and instead maybe a generic (cut to fit) service part. Notice that its marked Motorcraft ;)
Just trying to help
« Last Edit: May 07, 2017, 03:32:27 PM by J_Speegle »
Offline martin
« Reply #5 on: May 08, 2017, 01:59:16 PM »
Jeff
I just i realize your picture's are from an S-code, i looked at the mansfield picture because it was more detailed. When i look at your pictures more closely it seems to be the same as the mansfield picture. So no difference between a S-code and a S-code GT.
By the way I have a 69 mustang mach one with a S-code.
« Reply #6 on: May 08, 2017, 02:17:25 PM »
Yes they are both the same engine.  Have a couple of friends that have S code Mach I's that are restored. Back when they were done we had some challenges to start out with since so little attention is paid to that engine compared to the CJ's  as you have surely discovered ;)
