Author Topic: radius arm/rod and steering stop bracket finish. 66 mustang  (Read 860 times)
Offline austr6
Hello, i am checking to see what finish should be on the front radius rods and steering stop brackets (bolted to lower control arms).
are they natural steel finish or painted?
Richard.
May 20 1966
GT Fastback
A code,
Auto ,Air conditioning, Power Steering
Standard Interior
6R09A202931
Re: radius arm/rod and steering stop bracket finish. 66 mustang
« Reply #1 on: May 01, 2017, 03:45:31 AM »
Richard.
The stops were a bare steel and the strut rods were also unpainted steel. Some consider the the strut rods a heat treated steel myself typically have seen originals and service replacements a bare steel not as dark as heat treated steel. If you paint them the faux finish better look like bare steel.
Offline austr6
« Reply #2 on: May 01, 2017, 04:38:36 AM »
"If you paint them the faux finish better look like bare steel." What is this finish?
May 20 1966
GT Fastback
A code,
Standard Interior
6R09A202931
« Reply #3 on: May 01, 2017, 04:47:39 AM »
They were not painted originally. With that said some people will use a paint that looks like metal.  Faux finish= imitation of the original finish.
Offline austr6
« Reply #4 on: May 01, 2017, 05:06:14 AM »
OK cheers.
May 20 1966
GT Fastback
A code,
Standard Interior
6R09A202931
« Reply #5 on: May 01, 2017, 10:27:03 PM »
They are mentioned in a number of threads.
Here is an example and reference I found using the search feature
http://www.concoursmustang.com/forum/index.php?topic=5890.msg33184#msg33184
