Author Topic: Autolite or FoMoCo  (Read 2078 times)
Offline preaction
Autolite or FoMoCo
« on: May 01, 2017, 12:24:21 AM »
Is there a simple answer to when distributor castings went through the change of being marked Autolite to being marked FoMoCo or vise versa ? I haven't looked much as to the differences between the two (markings) but as combing through this part and many others this kind of ID and time frame comes into play.
Re: Autolite or FoMoCo
« Reply #1 on: May 01, 2017, 01:08:28 AM »
No simple answer I am aware of .The transition on the distributors seemed to happened in the early part of the 67 model year relatively speaking. I have seen some bouncing back and forth of trademark during the early time period at least on some of the ones i have studied.  It also seemed to vary on the distributor application also. I have only studied the 289 hipo and 427 duel point . Those seem to have different change over times. Others will have to comment on different application change over times.
« Last Edit: May 01, 2017, 01:11:58 AM by Bob Gaines »
Offline preaction
« Reply #2 on: May 01, 2017, 04:17:32 PM »
Thanks Bob, so the progression would be FoMoCo, Autolite, then Motorcraft, Motorcraft being service replacement parts ?
« Reply #3 on: May 01, 2017, 08:05:33 PM »
By 1972, I think that most if not all of the distributors were marked MOTORCRAFT.
« Reply #4 on: May 01, 2017, 10:19:12 PM »
Think its much easier to compare assembly dates on the dist in question (as long as it hasn't been restamped)  to get your answer and to find a usable one for your application
Offline preaction
« Reply #5 on: May 02, 2017, 12:40:45 PM »
Jeff you are right, in this instance a view of the big picture was the point.
« Reply #6 on: May 02, 2017, 12:49:10 PM »
You got it. As I had said before there seemed to be a little flip flopping (according to dates on dist)at the transition point. Not a hard and fast line which probably had to do with supplies. I can't give any insight on the Motorcraft  transition. I never paid much attention to the Autolite /Motorcraft transition because for my purposes i was not concerned about anything marked Motorcraft.
Offline preaction
« Reply #7 on: May 02, 2017, 05:22:01 PM »
The distributors that made me ask are two I just picked up one is C5AF-E with a date of 6M6, and a C6AF-AZ with a date of 6M19, the first being a FoMoCo and the second a autolite. The first being a Shelby application and the second a non production sohc part.
