Author Topic: 64 1/2 K code Leaf Spring Markings  (Read 701 times)
Offline FXguy
    • Early 64 June K Convertible Restoration
« on: April 24, 2017, 04:27:37 PM »
Wondering if anyone has info (other examples) on these markings I found on the leaf springs for this June K code convertible.  There is a white daub on top of each that looks to have been applied after assembly (see partial where the band was originally.  The markings on the other side run the length of the print from near the forward bushing to the center mounting hole.  Only a few inches of these markings are visible after assembly.  The only other markings are the green and yellow daubs on the shortest spring.  These pics were taken fresh out of the Evaporust.
TIA.
-Scott
Scott McMullen
64 1/2 K Code Specialist, pre/early production historian, collector, and restorer.
"I'm absolutely sure of one thing, and that is I don't know everything...there is always something new to be discovered...and that's where the fun is."
Re: 64 1/2 K code Leaf Spring Markings
« Reply #1 on: April 24, 2017, 06:56:23 PM »
No haven't found markings there before. Of course they would not be visible on an assembled spring but when disassembling them haven't found markings of individual leaves.
Thanks for sharing
Offline FXguy
« Reply #2 on: April 24, 2017, 08:16:26 PM »
Thanks for sharing
Thanks for the quick reply Jeff.  With the springs assembled a few inches of the longer markings will show near the forward bushing.  I'm going to recreate all of these so don't be surprised if you see these in-person in the near future  :D
BTW, I've seen a white stripe at the rear on some early K coupes, but this is the first time I've seen this towards the front and in this style.
-Scott
Scott McMullen
« Reply #3 on: April 24, 2017, 08:32:40 PM »
I've not see a white mark on those early K codes. How early are you referring to and from what plant?
Offline FXguy
« Reply #4 on: April 24, 2017, 09:18:23 PM »
One had a planned date of June 8th, the other June 9th, both Dearborn, and both had Los Angeles DSOs.
-Scott
Scott McMullen
