Author Topic: 67 with Tilt Column wiring sleeve  (Read 830 times)
« on: April 22, 2017, 09:33:03 AM »
Looking for an ideas on what to use on a 67 Mustang w/Tilt-away column to sleeve over the Turn signal harness wiring coming out the lower port of the steering column. It seems there was something there before but now I have nothing.
Re: 67 with Tilt Column wiring sleeve
« Reply #1 on: April 22, 2017, 09:39:01 AM »
The tilt column had its own unique wire cover. It is much like the non tilt column cover but a bit shorter. I see if I can get some photos.
« Reply #2 on: April 22, 2017, 10:04:40 AM »
I should have something also.  From a color and texture perspective I think heat shrink tubing (without shrinkage) would be a decent substitute
« Reply #3 on: April 22, 2017, 01:17:16 PM »
+1
That is where I would start. Might compare a few different suppliers since the thickness may vary between them but other than a slight thickness difference and a less smooth or slightly glossy finish I thing it would work for you and would be the first place I would start
Offline 67350#1242
« Reply #4 on: April 23, 2017, 12:16:20 AM »
I've used this harness sleeving for other purposes.  I think the semigloss tubing would be a good match if it is big enough.  Kurt
http://www.cycleterminal.com/sleeve-tubing.html
« Last Edit: April 23, 2017, 12:23:11 AM by 67350#1242 »
67 Coupe SJ 11/16/66
67 GT350 SJ 2/01/67
« Reply #5 on: April 23, 2017, 10:29:04 AM »
Thanks Kurt, looks good
OK, need input from somebody with an original...Sizes available that might match, 9/16", 5/8" or 3/4" (I.D.), available by the foot, up to 20-foot lengths  :o
