Author Topic: Metuchen part colors  (Read 1371 times)
Offline Raven R Code
  • 428CJ ~ 4 spd ~ 3L50
« on: April 19, 2017, 10:16:31 AM »
I have a march '69 build . Looking to paint suspension and steering parts....along with clutch equalizer bar and related mounting brackets. Also need paint info for steering gear box. I know most suspension is black but not sure on correct sheen. And not sure if strut rods, shock tower caps and hood hinges are slop gray or phosphate
Dave
« Last Edit: April 19, 2017, 10:59:01 AM by Raven R Code »
Dave
~ Do it concours or don't do it.
Re: Metuchen part colors
« Reply #1 on: April 19, 2017, 04:42:31 PM »
Lets see if we can help. Will at least get started
Clutch equalizer bar
- Bare steel so like new metal look of the arms and tube with darker welds and bluing of the metal adjacent to the welds
Related mounting brackets. Frame mount is bare steel with the weld detail like described above
Paint info for steering gear box. - Box and parts not painted but bare metal of different shades and finishes. These are covered in a number of threads. Over the surface you would normally have some paint marks that can differ based on what type of box (PS or nop-PS for example) it is. And over the top of that it is possible that the top of the box was blacked out (paint running down the sides and such) with a large paint brush application but I don't have solid documentation that NJ did or didn't like the other two plants but it might be a good guess
Can't think of anything about the front suspension or rear other than the lower control/A arms being part dipped and the shocks being semi-gloss black, being painted.  Steering linkage, spindles, strut rods, sway bar, end links, brackets, disc brake mounts, nuts and bolts are all natural of different finishes, tones and looks. Some with machined surfaces on an otherwise heat treated cast finish. All or most are covered in prior threads a number of times.
Hood hinges and front upper shock mounts (shock mounts are covered in the FAQ section- at the top of the face page of this section) are Phosphate and oil
« Last Edit: April 19, 2017, 04:50:54 PM by J_Speegle »
« Reply #2 on: April 19, 2017, 07:01:48 PM »
Thanks Jeff!
That's enough to get started. Are the hood hinge springs black or phosphate as well?
Dave
Dave
« Reply #3 on: April 19, 2017, 07:29:05 PM »
Same as hinges
