The latest update for the Mustang Hardware Spreadsheets is available. The latest files names all end in 03, example - MHW64-66AP03.xls. They are all dated 04/08/17. I recommend that the previous versions not be used, unless you have made some changes to your own files.
The biggest updates are for years 69 thru 73 where a brief dimension was added where the previous was unknown. The dimensions were found in the Osborn publication, “Ford Standard and Utility Parts Catalog, January 1969” (AM0205). Unfortunately only a minimum of data could be used in the spreadsheets as the catalog relies more on a visual representation to determine what a part is instead of a full detailed drawing. I recommend that owners of 69 thru 73 Mustangs get a copy of this parts catalog to fully identify specific parts referenced in the hardware spreadsheets.
To make using the Library easier, the most current version of the Hardware Spreadsheet files will appear in the original post and previous versions attached there will be deleted. A new post will refer users to either the original post or the library for downloads.
