Author Topic: ID a Bendix Master Cylinder 2227061  (Read 2867 times)
priceless
  • Guest
« on: April 07, 2017, 11:21:39 PM »
Can anyone ID a Bendix Master Cylinder with the Bendix logo and the numbers 2227061?
Any help appreciated,
Rich
Re: ID a Bendix Master Cylinder 2227061
« Reply #1 on: April 08, 2017, 12:40:03 AM »
Rich
2227161 is typical 67-70 Mustang disc brake master. I don't know what 2227061 is .
« Reply #2 on: April 08, 2017, 03:27:54 PM »
Maybe someone will have access to a Bendix catalog that lists all the numbers
Offline 196667Bob
« Reply #3 on: April 14, 2017, 02:26:30 PM »
Rich
Rich : The Bendix Master Cylinder you have with Casting # 2227061 is for 1967 Mustangs with Power Drum Brakes. It is original Ford Part # C7ZZ-2140-B, which was later replaced by Part # C7ZZ-2140-G.
Hope this helps.
Bob
MCA 04909
« Reply #4 on: April 15, 2017, 03:36:36 PM »
I just removed the disc brake MC on my 65.  Part # 2225032, the Bendix logo, R5 and a date casting, which I can't decipher, 285.  Is this original or a replacement ?  Thanks for the help.  Brian
Offline preaction
« Reply #5 on: April 15, 2017, 04:35:30 PM »
I believe 285 is the day of the year.
« Reply #6 on: April 15, 2017, 04:57:21 PM »
Quick way to tell on a 65 disc master without looking at the casting numbers which can be very problematic on a installed master is to see if it has the brass adapter fittings to adapt to the flared brake lines. The change over was in early 66 so if it has the brass adapters most likely it is still a original or at least a period master. The updated style had flared fittings made into the casting making the brass adapter unnecessary. The old style was superseded for the new style in dealer and auto parts stores stock. When they were used up the new style was sold.  The updated master would be a direct replacement needing no modification other then stretching the factory flared lines a little to compensate for the missing adapter length.
« Last Edit: April 16, 2017, 02:48:55 AM by Bob Gaines »
« Reply #7 on: April 15, 2017, 05:01:32 PM »
FYI NPD sells a special faux looking adapter which is actually a extension playing the part of a adapter. It gives the look of the old style 65 disc brake master adapter to a later 66 style master.
Offline rodster
« Reply #8 on: April 15, 2017, 11:32:03 PM »
I'd say original. Here's mine from my Dearborn 65 with a scheduled build date of April 19.
1965 Dearborn Mustang Coupe
Raven Black - Palomino Pony
1967 Dearborn Mustang Conv.
Wimbeldon White - Red
1984 SVO - 2A
