Author Topic: rebuilding AC defrost damper position switch  (Read 1481 times)
« on: March 29, 2017, 08:41:21 PM »
I ended up rebuilding an AC defrost damper position switch and thought some tips might be useful.
Re: rebuilding AC defrost damper position switch
« Reply #1 on: March 29, 2017, 08:42:43 PM »
Thanks for posting and sharing this John
Offline preaction
« Reply #2 on: March 29, 2017, 09:39:17 PM »
This is a perfect candidate for the library, thanks for taking the time to post what you found. John can you remember where you found your vacuum tool ?
« Reply #3 on: March 29, 2017, 10:07:18 PM »
John I have done the same repairs. Good that you were able record the process.
Thanks.
« Reply #4 on: March 30, 2017, 05:36:49 PM »
The tool creates vacuum or pressure (selectable). Magnum Pro calibration pump model MVP-600.   For casual use your daily driver engine or wife's car 😀 will be more cost effective
« Last Edit: March 30, 2017, 05:39:15 PM by 67gta289 »
Offline preaction
« Reply #5 on: March 30, 2017, 07:47:19 PM »
Thanks, as you know there's nothing like having a nice tool for the job.
