Author Topic: Screw holes placement for hood pin assembly?- 69 San Jose  (Read 1233 times)
Offline 1969CJ
  • 5094995129
« on: March 25, 2017, 02:30:56 PM »
 The screw holes on the hood for the outer hood plate on my R code are not the same from RH to LH.How are holes supposed to be placed in hood? Pics? Thanks.
« Last Edit: March 25, 2017, 07:10:55 PM by J_Speegle »
1969 Mach 428CJ built 1/30/69
1973 Convertible
Offline 7Lscjracer
Re: screw holes placement for hood pin assembly
« Reply #1 on: March 25, 2017, 04:40:10 PM »
Standing in front of the car, two at the back and two at the front.
Looking at it like a clock face, approximately 11 & 1 and 7 & 5, not 12 & 6 and 9 & 3.
The holes in the hood pins are orientated 12 & 6 though.
There are good examples in Marcus's article if you click on the "guide to original 1969 and 1970 hoods" section within this page here:
http://www.anghelrestorations.com/mustang-factoids.html
« Last Edit: March 25, 2017, 04:48:33 PM by 7Lscjracer »
Bought May '81, sold Sept '20
« Reply #2 on: March 25, 2017, 05:59:50 PM »
Where was your car built?   There was a arrangement of ho workers were suppose to install them but want to check to see if your plant followed that ;)
Offline 1969CJ
  • 5094995129
Re: Screw holes placement for hood pin assembly?- 69 San Jose
« Reply #3 on: March 25, 2017, 06:45:00 PM »
Car was built 1/30/69 in San Jose
« Last Edit: March 25, 2017, 07:10:45 PM by J_Speegle »
1973 Convertible
« Reply #4 on: March 25, 2017, 07:35:53 PM »
Thanks narrows down the search for examples
From a week or so before your car was built at San Jose
From possible a couple of days after your car was built at San Jose. Either very consistent or same worker
As a note I often will adjust the pins so that I can insert a nylon washer between the pin and the hood plate to eliminate the scratches when not showing or displaying.
