Author Topic: 66 SJ Fender Bolts  (Read 1528 times)
Offline nationalmustangs
66 SJ Fender Bolts
« on: March 22, 2017, 04:03:17 AM »
hi all, getting the fastback ready for the paint shop,
what are the correct length and tops for the bolts that are used for the fenders?
thanks
« Last Edit: May 22, 2020, 06:46:05 PM by J_Speegle »
6R08A160444 - Plant: San Jose CA, Date: Feb 01, 1966 DSO: Los Angeles
Re: 66 fender bolts
« Reply #1 on: March 22, 2017, 07:39:59 AM »
You should include the assembly plant and build date for this, and probably most questions.
Re: 66 fender bolts
« Reply #2 on: March 22, 2017, 05:38:19 PM »
+1  - Will be waiting for your response
Re: 66 fender bolts
« Reply #3 on: April 11, 2017, 09:21:08 AM »
Hi guys
I have now updated in my profile below the details of my car below,
Offline markb0729
  • South Jersey
Re: 66 fender bolts
« Reply #4 on: April 11, 2017, 09:56:42 AM »
Check the hardware spreadsheets in the Library section.
65 Dearborn Built Fastback
289 4V, C4, PS, PB, No A/C
Re: 66 fender bolts
« Reply #5 on: April 11, 2017, 03:18:27 PM »
Hi guys
With that info its very likely that the fender bolts used the solid washers with bolt heads with the  "" quote or tick marks.  On some examples a different bolt was installed in the rear most top hole with the toothed washer but you will likely be better off by using all the same flat with the tick mark bolts along that edge, in the door jamb and from below.
As mentioned the hardware spread sheets will give you length and size
Since your getting the car "ready for the paint shop" remember that none of the front sheet metal (plenty of prior threads discussing this) was installed when the car was painted.  ;)
