Author Topic: Early Hipo exhaust question  (Read 3272 times)
Re: Early Hipo exhaust question
« Reply #15 on: March 13, 2017, 05:52:02 PM »
Hello,   <<<Too early for Arvinode exhaust, should have been a transverse system.>>>   I have been in contact with the original owner and he states that nothing was done to the exhaust on the car from the time he picked up the car, until we purchased a few years later.   Also, he did not drive the car enough to replace tires, brakes, shocks or any other consumables.
I can say that the original exhaust on my car did NOT have the rectangle supports on top of the 'mufflers',   the exhaust system was one pc. from H pipe back to the turn downs at the rear valance.
The car does have the 64 1/2 hood & headlight buckets,  heater switch,  spare tire bolt.   The car is Rangoon Red with red interior.
later, Karl
Keep in mind that 50 years is a long time.  Previous owner's recollections are not always accurate.
If your mufflers do not have the rectangular tops, then those are not Arvinode mufflers.  I think we need to see a pic of what you have.  The only factory dual exhaust used on the assembly line for K codes at the time your car was produced was the transverse setup.
Not sure if you are aware, but your car is most likely a pre-production example.  Meaning, your car may have been built before the re-start of Dearborn for the 1965 model year.  This was the conversion/re-tool time from 64.5 mustangs (generator cars) to regular 65 (alternator cars).  Dearborn re-started the unit numbers with 250001.  Same sort of thing that happened earlier at the beginning of mustang production.  Any of the cars with 05C scheduled build dates were actually pre-production cars and not actually built that day.  09C was the actual first day of assembly plant production.  I have not studied the 64.5 to 65 transition, but 01H scheduled build dates could be used the same as earlier, to designate pre-prod.
If I were you, I'd examine the car very closely looking for anything that appears different or out of place.  It could have been a show car or some special use.  What's the DSO?
« Reply #16 on: March 13, 2017, 05:52:59 PM »
If it's the axle bump it might be one of these, if not, I'll see the car this week and can document anything you like Charles, Thank you!
Would suggest starting another topic to discuss your car.
Offline 69cobrajetrugae2
« Reply #17 on: March 13, 2017, 06:36:04 PM »
Okay
Offline svo2scj
« Reply #18 on: March 19, 2017, 03:38:14 PM »
So this is what I wake to ...............Look at all this activity !!  (in a month)  Karl@GT  Glad you found this site (or did Nathen) LOL    Lot's of helpful people , much more involved with "specifics" of cars then you will find at other sites/facebook etc etc!  Look at Charles's post above..........he firgured out pretty quick by the number.
MY GUESS IS YOU ARE GETTING BUSY with car!   (Really glad I didn't buy it, would have been sold by now/LOL) I have a trip home next week, will see if I can visit (tried to by a truck in Boyertown/long story).
Though you know Mustangs, go easy and slow with car.  Too many will give the red azz on "build" if you keep it the way it was delivered.  I would build it the exact way even with the AFB's (too much story with the car to loose)
Mark
P.S.  Don't let me come there and find a 715 Cathedral Float Holley "just beacuse you had some laying around" !
